Where to get Wideband o2?
I want a wideband o2 sensor for my car, I'd like to get one that I can watch live as I'm going down the road and tune the car on the street and watch it during racing.
Is there anything available for me?
Originally Posted by houseofboost
Can these be used for any period of time? Or just for short periods?
joel
Kick ***!
Anyone have one of these?
Some guys wire it to a switched 12 volt so it comes on when you start the car. The only problem is you need it to only turn on after the car cranks and starts due to possible voltage spikes while cranking. I haven't been following how they've accomplished this but I think they figured something out.
Thanks for the information guys! I definately appreciate it.
I think I am going to get one, should be a very handy tool and I am kind of a worrier, so it will make me feel better being able to keep my eye on it.
Originally Posted by Bink
You can run it full time. I have this setup-> FJO Wideband O2 and it's always on - have the gauge in a pillar pod. FWIW.
joel
joel
Kick ***!
Anyone use the MachV unit?
$349
And...
$44
There are 2 analog outputs from the control box the first is a 0-5v readout that will feed just about any stand alone Engine Management Systems or dataloggers and a 0-1v output which will feed your stock ECU so you only have to use 1 O2 sensor. No welding an extra bung on here!
And...
Narrowband to Wideband Gauge ConverterThis device allows the wideband output signal from the above wideband kit to feed a narrowband o2 sensor like the offerings from Autometer. You could simply use the narrowband output from the wideband kit but it simulates what the stock ECU wants to see and the o2 gauge will continue to be very erratic. With this device it drops the 0-5v output to a linear 0-1v output and thus your blinky light o2 gauge will suddenly be.... accurate!
Originally Posted by Draco
I just bought the brand new Dynojet Wideband Commander system from Xtreme motrsports for less then the prices I saw on FJO's website. Comes with an autometer gauge, onboard logging, USB interface and PC software to log along with TPS and RPM.
joel
Moderator
When I tried to view the pricing sheet on FJO's
page my browser got into some jiggy page loop.
I have also seen today dynotune.org ($429)
and innovate ($349 + ala carte) and the dynojet
($549?) and of them I like the looks of the
Innovate better, as I would keep it as a loose
tool for using on my own and others only as
needed. I'm waiting for the next special.
