Generation IV Internal Engine - Sleeved Blocks
View Full Version : Sleeved Blocks
N2OBaby
06-05-2012, 04:18 PM
I've read alot of magazines Camaro Performers,GM High Tech Performance,Car Craft,Popular Hot Rodding & Hot Rod are among my favourites.
The article in Camaro Performers is about Darton Sleeves and the article in GM High Tech Performance about ERL(also an advertiser here) as well as the Website for QMP(which uses Darton Sleeves) about building big cubes in LS small blocks.
Anyone out there running a 436(4.165 bore w 4 inch stroke) or 468(4.185 bore w 4.25 stroke) or similiar cid LS3?
delphigto
06-05-2012, 05:06 PM
My last motor was a erl ls2 block 454. It was 4.185 bore 4.125 stroke. It was a superdeck block. The only regret I had was not going 4.2 bore 468. I dont think i would go 4.25 stroke and have a unsqaure motor.
Im running a drysleeve erl in my new car. Its 4.125 bore 4.0 stroke. The 454 made a ton more power but it was a different build. The 427 is a 11.1 com, cam specs are 240/251 .630/.623 on a112, stock ls3 heads, and a fast 102. It made 530 whp when built. The 454 is a 12.2 comp on e85, cam specs are 247/263 .670/.670 on 113+3, prc 285cc heads, and a fast 102. The 454 pulls so much harder. I know its like comparing apples and oranges with these motors. Hope this helped.
N2OBaby
06-06-2012, 09:53 AM
Hope this helped.
Yes this did help.
How is running E-85 working for you on the street?
Later-A-body
06-10-2012, 01:30 AM
I am also running an ERL 430 CI LS7 motor (4.130 x 4.0). Cam specs on mine are a little more mild at .630/.640 226/242@.050 on a 115 LSA, and ported Dr. J's Performance LS7 castings. CR is 11.2. ERL was very good to work with. I worked with Shane. ERL did not recommend any larger than a 4.0" stroke if you really plan to drive the car on the street, and put miles on it due to the potential oil consumption issues with the piston rock caused by a larger stroke. I followed their recommendation even though I wanted a 4.125 stroke.
N2OBaby
06-11-2012, 03:41 PM
Later-A-body that sounds neat those Dr J heads sound like good quality in every article I've read.
KILLERARMY
06-11-2012, 03:52 PM
ERL is fixing me up with a LS2 434 ci (4.155 x 4.000) Dry Sleeve motor.
N2OBaby
06-11-2012, 03:57 PM
What cam/CR/Heads,Intake,etc Ya running.
This thread is very interesting as I've read about sleeved blocks but not anyone running them
KILLERARMY
06-11-2012, 04:50 PM
West Coast Cylinder Heads LS7 265cc LSW All Pro Heads/No cam or FAST Intake as of yet until the heads arrive.Just waiting for the motor from ERL Performance. Check this youtube video of a ERL Performance Dry Sleeve motor.
http://www.youtube.com/watch?v=ZJ3tcg_JG8E
http://www.youtube.com/watch?v=UzK9AAT34iw
I have contacted this 2 guys about ERL Performance and they sent me video of their ride.The G8 is a LS3 434ci Dry Sleeve motor and the Camaro is a LS3 427 Dry Sleeve motor. Enjoy
WKMCD
06-11-2012, 08:02 PM
My LS2 block 427 has Darton sleeves done my Shawn Miller. 4.125 bore with a 4 inch crank. The Darton sleeves are a hell of a lot harder and stronger than the stock liners when matched with the correct pistons and rings, it should last a long time assuming it's put together right. I could have gone bigger but the 427 is just so iconic in the vette.
http://i54.photobucket.com/albums/g93/WKMCD/VSEngine5.jpg
N2OBaby
06-12-2012, 07:52 AM
There is some great stuff here guys, it sounds like it would be easy to build 450+ CID engines.
Forced Induction on that Gen 5 Camaro looks interesting but N2O injection sounds better to me.
LSX-coupe
06-12-2012, 08:56 AM
Erik at HKE builds a 468 with sleeved blocks 4.185 x 4.25 and will still take a 200 shot. Once you go over 4.185 bore keeping head gaskets on it will be the problem. As you lose all the clamping area.
N2OBaby
06-12-2012, 01:08 PM
It still amazes me that an engine that was designed to be a 346 or 364 CID can be resleeved and become a 427,434,454,468 or 470+ CID.
COPO9560
06-12-2012, 06:05 PM
LS is not the only one that has grown. The original Mark II BBC was 427 cubes. You can now get a low deck version up to 588 cubes. Original SBC was 265 and you can get a crate 454 now. Where there is a will and a large checkbook anything appears possible.
pewterthang
06-12-2012, 07:20 PM
I was just posting in the enternal section about freshing up my 402 but it look like going 427 is becoming more of an option! Resleeve the ls2 an buy pistons an use my crank and rods! You guys have me thinking. HOW MANY MILES YOU GUYS PUT ON YOUR 427s????
pewterthang
I DAILY DRIVE, is why i asked the question, thaks guys.
WKMCD
06-12-2012, 08:25 PM
That's exactly what I was going to do. My 403 was a bit of an R&D dyno mule with about 20k street miles on top of that. Leakdown on a few cylinders was 25%. The only real difference in price was the having the liners done with was about 1800. You'll probably need pistons and rings anyways to freshen the 402.
pewterthang
06-13-2012, 08:46 AM
Who did you let resleeve an redo your engine? Did they supply pistons?
WKMCD
06-13-2012, 03:01 PM
Non forum sponsor...
My6speedZ
06-13-2012, 04:31 PM
What would you big cube guys say the average is for these big cubic inch sleeved combos?
427 averages around say 550-600
454 averages say 600-650 rear wheel?
delphigto
06-14-2012, 06:43 PM
Yes this did help.
It worked fine for me. I sold it to a buddy and he has had no problems with it. I sold it to buy a 06 z06 and hated it. So I sold it and bought a 10 camaro with a resleeved 427. Im thinking of changing pistons and going to 13.5 comp. Its making 530whp now on stock ls3s. Im shooting for high 500s. Im either going to go with mast ls3 or ls7 heads or prc ls7 heads again. Ive been trying to get ahold of eric before I make my decicion. I was going to order prc ls7s the other day but couldnt get tsp to make me a deal.
blackonblacksls
06-14-2012, 06:54 PM
The block in my car is a sleeved ls1 block. 4.130 bore 4in stroke.
N2OBaby
06-15-2012, 01:22 PM
13.5:1 CR sounds about right for E-85, would love to see that cam. :hail::hail:
So LS7 heads(like DR J's Airwolf LS7) and intakes(such as GMMP Single Plane) fit LS2/LS3,etc blocks?
delphigto
06-15-2012, 06:38 PM
The gto made 604/547 and the camaro made 530/500. The gto cam is 247/263 .688 lift on a 113+3 and the camaro is 240/251 .630 lift on a 115.
N2OBaby
06-18-2012, 02:52 PM
Good stuff there.
A 4.13 bore from an LS1 who woulda thought when they 1st came out that you could get a 4.200 bore out of one??
rennocneb
06-18-2012, 03:26 PM
Thats my G8 in the video posted by Killer Army. BTW its for sale if anyone is looking for a wicked G8 that was done right lol. Anyway the dry sleeve blocks from ERL i think are very solid pieces. Their machine work is top notch, as far as the power estimates everyone is throwing out its gonna depend a ton on your driveline, and how drivable you want the combo. My G8 sounds wicked, runs damn strong, and my wife can drive it to get grocerieces without me worrying she will kill herself, so it is a bit under 550whp around 502, but thats through a stalled unlocked converter on a stingy dyno. With a manual car id think 550whp out of my combo would be very doable.
delphigto
06-18-2012, 04:23 PM
I asked him a couple questions about it and he never answered them on the g8board. Is he still trying to sale it?
rennocneb
06-18-2012, 04:35 PM
sorry delphigto if i didnt respond i just got back from my hooneymoon hence why its for sale lol. i am looking to buy a house and would make someone a good deal on the car.
rennocneb
06-18-2012, 04:44 PM
as to the op question though i dont think id build a really serious lsx without a sleeved block. the sleeves are just so much stronger
N2OBaby
06-18-2012, 05:08 PM
I just read an old thread about Tony Mamo's 383 LS engine wonder if the same magic could be applied to a 410(4.13 bore with 3.825 stroke) or 414(4.165 bore with 3.80 stroke) sleeved LS1/2/3/7?
delphigto
06-18-2012, 08:21 PM
Congrats. Pm me your lowest price. Not wanting to buy another sports car with a baby on the way but you never know if the deal is right. How's the tune? Does it still need touched up?
Sorry to op don't mean to hyjack your thread.
