Generation IV Internal Engine - Buy a used LS3?
Raoul-Duke
06-06-2012, 09:55 AM
My LS1 has 74k on it and I am deciding whether to keep the car or not. Down the road I am planning on putting a blower (D1SC) on it and internals as well. I will prob eventually do the bottom end too.
On the other hand....
If I am planning on keeping this car the mileage is getting up there and my biggest concern is reliability.
Where are some good places to find a low mileage used LS3 for a good price and how much does one typically go for??
I am in love with the Ls3...
Thanks
427 zeo6
06-06-2012, 11:45 AM
New one from GM is under $5K why gamble?
Raoul-Duke
06-06-2012, 01:20 PM
I thought they were round $7k. And if I can find a used one with under 15k miles I'm sure I will be saving some decent $$. Maybe out of a crashed car
Tainted
06-06-2012, 02:36 PM
if youre willing to settle for an iron block, the L92 is even cheaper. find a shortblock from someone, and add a nice set of heads etc and you got a great motor for under 7k
Raoul-Duke
06-06-2012, 03:46 PM
See that is what I was originally planning on doing. But I was under the impression that buying the 6.0 block. (Plus all the components, internals, computer, etc) would be considerably more what a LS3 would cost brand new...
My lack of knowledge with the subject is what I really want to be enlightened on...At 18 I had a 94 z28, then a 2004 GTO, and now my 01 Z28 which I have had since I was 21, now I am 25. I have never really dealt with anything but LT1's and LS1's...
Tainted
06-06-2012, 05:01 PM
well the L92 is a 6.2L block. essentially an LS3 with a few differences.
If you picked up an L92 shortblock with the flycut pistons, added a ncie H/C setup (roughly 3k) you could have a very stout motor without having to "build" the bottom end.
Coban
06-06-2012, 06:01 PM
L92 is aluminum block... LY6 is iron.
Tainted
06-06-2012, 06:13 PM
Are ya sure about that? Its found in large escalades etc. im pretty sure they are iron blocks, or there are both iron and alum versions
01 blue ss
06-06-2012, 09:16 PM
L92 is an aluminum block. I just built me a 416 with one. The biggest difference between an LS3 and L92 is the displacement on demand in the L92.
1981TA
06-06-2012, 09:26 PM
I've got a L92 and just had the lifters replaced under warranty. It's aluminum.
OP, regarding the LS1, have you considered rebuilding it?
bad_408_vert
06-06-2012, 09:37 PM
Why even rebuild the ls1 at 74k miles?
People do cam & heads on 100k + ls1 motors.
Op unless you just want more cubes to start with , why not mod the ls1?
Raoul-Duke
06-07-2012, 01:49 PM
Im planning on putting a blower on it down the road which I would prob have to do the bottom end?
Well the thing is I am really going for reliabilty and will be keeping this car for the long haul. I dont feel too comfortable with 74k on it all ready.
Plus the extra cubes would be nice.
Or could I just build a blower motor out of my current LS1 if I beef up the bottom end? Is it worth it or better to do the iron block? Or just screw it and get a ls3?
I am looking for around 700rwhp+ when it is all said and done.
What would you guys recommend if you were in my shoes
bad_408_vert
06-07-2012, 02:08 PM
iron block cheapest & best for boost, it weighs 80lbs more than aluminum but does it really matter when you have 550+ rwhp.
Ls3 + FI or Forged ls1 + FI may cost about the same in the end.
Finding a good deal than rebuidling ls1 would be better idea.
My6speedZ
06-07-2012, 02:34 PM
Iron block for boost.
LS3 for a healthly all-motor semi budget build.
I myself have been eyeing some LS3 stock replacement's from Thompson Motorsport
Check them out. Stock rebuild with clevite bearing for a really good price. Add in a few hundred to put the Gen4 block in the T/A. A nice set of heads you could have a 500+ car for 7k I would say.
Raoul-Duke
06-07-2012, 03:56 PM
So the Iron block is the best way to go for boost huh?
How much you think I can get for my LS1 ? lol
Is the 6.0 better for boost just because it is iron?
Tainted
06-07-2012, 04:18 PM
Go for the biggest bore you can (ls3)
Iron is better for boost because the cylinder sleeves/wall are much thicker, and block has less tendancy to flex with more holding power.
87silverbullet
06-07-2012, 04:49 PM
Not really. There are guys with well more than 550rwhp with aluminum blocks on boost. Mark Koehler pushed 1300 rwhp out of a stock ls2 block and ran 7.99 before he cracked a sleeve
I say again, The aluminum block can handle more power than you think. It doesn't always have to be an iron block for boost.
This is partially true when you are pushing alot of boost but we are talking well past the 1000rwhp category. So this wouldn't be the case for the OP.
There have been guys here that have pushed aluminum blocks past 20 psi like its and everyday thing. Skinnies, with his aluminum block 5.3, 8's in the rx7 and 9's in the ltd. Mightymouse, when he had the stock ls2 block, 995rwhp street car. AutomagicLS1 988 rwhp on a stock block forged internal ls1.
Hell, Edelbrock sells a blower for LS3 camaros that put it in the neighborhood of 699 crank hp with a freaking warranty.
OP, just rebuild your LS1 with forged internals with the stock crank and you can slap a D1 or a 76mm turbo kit on there and obtain your goals.
Raoul-Duke
06-07-2012, 05:20 PM
So if I go the forged internal path with my ls1 even though I have 74k on the clock, it will not sacrifice any reliabilty?
My engine would pretty much be new besides the block, am I correct when I say that?
I dont really plan on pushing more than 800rwhp, However I would have to push more boost in my Ls1 to attain the same power out of the Iron block because of the displacement.
Is there a difference between the two when it comes to price and best bang for your buck?
Im just trying to figure out if its worth it to still do the iron block in the long run or if for what I am going for, will my LS1 will do the trick (forged) but I am going to put some of the best components I can in it, so will it still be cheaper?
87silverbullet
06-07-2012, 05:34 PM
Forged does not sacrifice driveability or longevity in an engine. Who you get to machine it will make or break the reliability of it.
Yes it would be all new except the block and crank. Displacement is only one factor in making power in a boosted setup. The heads and cam will dictate power just like a N/A motor, including the amount of boost you run.
Since you have an LS1 block already that puts you ahead of the game since you already have it and don't have to buy a block. If you just want to be able to drive around in your car while you build an engine for boost then you can start seaching for a block. The LS2 block has the best walls for boost but iron block are found cheap all day long on here.
The budget iron block build is the stock crank 4.030 build. it gets you 370 cubes and wroks well with boost, depending on your cam and head choice.
Your budget aluminum build would be your LS1 since you have the block and crank and all you would need would be rods and pistons. Still works well with boost and take your pick on cam and head choice.
My6speedZ
06-07-2012, 07:19 PM
I know the Aluminum block will handle 700rwhp, for the cost though I was saying iron block. I was just thinking boost ready 5.3 shortblock from AES is 2600 and the 370 is 3200.
Throw in their hand ported 317's for a grand and your ready to rock.
Get your iron block have it machined then assembled, pick up some heads for it... do it a piece at a time and still drive your car.
Just throwing out different options for different situations.
Edit: Now that I am thinking about it a forged rebuild on your 347 would be a very realistic choice if your only plan on going D1 down the road.
Tainted
06-07-2012, 08:02 PM
I still say go big for an ls3 shortblock or any 6.2l variation. The larger bore is a huge plus, and if you get a stroker kit you can go up to 414ci i think.
Either way figure 500 for a bare block
2500 for a rotating assembly of your choice with bearings
Heads anywhere from $1000-4000 your choice
Cam/springs/blah blah blah $900
Gaskets, bolts, misc shit $500
So for a totally new, ground up build you can get anywhere from 5k-7k +
You would have the benefit of more CI, all new parts, forged pistons etc and you could have one bad ass motor with the quality parts to make it last a long time and make huge power to boot.
87silverbullet
06-08-2012, 07:45 AM
The ls3 can go to 427 but it is recommended more for N/A or just a small shot since it uses a 4.125 crank and pulls the piston way down in the bore to the end of the sleeve plus the piston is thin because of all the stroke.
I know you can go to a 416 with a 4.00 crank and 4.070 bore and a 418 with a 4.080 bore.
Your dollar figures are a little off but close. I just built a 416 with Callies internals and Wiseco pistons and the stock L92 heads cnc'd by PRC. I'm not done with it and I'm 9 grand in it.
For the OP I wouldn't even recommend a motor like that if he was going to boost it. A motor that size would require more than any kit out there and it would be more custom. The turbo size would be a 91mm minimum or an 88mm with a large exhaust housing to keep back pressure to a minimum.
OP you can throw a D1 or turbo kit (I'm partial to turbos) on you car now and slowly but surely build you a forged 370 with good internals and a set of good heads with a matching cam. 9's with ease all day.
My6speedZ
06-08-2012, 08:45 AM
LS3 block is going to run you more than 500 bucks. Think more along the lines of a grand.
I have to agree with Silverbullet, unless your getting a hooked up price I don't see you doing a turn key H/C build with all new shortblock and heads for anywhere near 5k. 7k is close but still a little low in my opinion. For reference My forged 347 was 5k and it was used with low miles.
I'm not disagreeing with you at all, if he's staying N/A I'd say LS3 or 416 for sure. I'm not a fan of the mega-long strokes. I just want the OP to have his budget in line. Make a list total it then double it. Got to think you didn't even list machining if he goes stroker and assembly. That another 1000-1500 there give or take.
Tainted
06-08-2012, 09:03 AM
As far as block goes, ive seen *used* ls3 blocks on here, and ebay.
Raoul-Duke
06-08-2012, 09:18 AM
So whats the boundary when it starts really pushing it when you compare:
A boosted forged iron block vs. boosted forged LS1
in rwhp terms,
I am just trying to see if is worth it to get the iron block in the long run.
I am not too crazy about the idea of the LS1 being maxed out around 700rwhp if this is the case. But I dont understand how it could be when people boost the hell out of 3.8s in grand nationals for example. Or so many more boost applications...
This is going to be a decision I will be pondering on for some time
My6speedZ
06-08-2012, 09:40 AM
That not the limit of the LS1 its just where most people max out the D1 you mentioned.
Raoul-Duke
06-08-2012, 10:05 AM
ah of course, Lets say I go F1. What would my limits be then? Would I need to get different forged internals for this when compared to the D1?
My6speedZ
06-08-2012, 10:26 AM
Man you know there are people that can tell you alot more about pistons and things of that nature than I can. But there are horsepower limits on the rotating assembly, however, most people over build their bottom ends IMO.
ARP 2000 bolts and main studs, and even the head studs to me are worth the little extra.
Hell if you want to do it on the cheap cheap buy a junkyard 6.0liter longblock slap a blower on it with stock bottom end and stock heads with a D1 and moderate boost and you can play for a while. People put those stock LQ4's through alot sometimes. Then when it finally pops, bore it over and put forged rods and pistons in it.
There are SO many ways to go about anything. You need to decide if your going to go N/A or FI first.
brandenash1
06-08-2012, 10:35 AM
ive got a short block out of silverado Hd truck. 6.0, if you're interested let me know!
Raoul-Duke
06-08-2012, 10:49 AM
I'm the type of guy that would probably somewhat over build it just so I would knowingly sleep safe at night that nothing will blow up.
For example,
I know you can get a nitrous kit for under $500, Back in 2007 I installed a dry kit on my 94z28 and it costed around $1200 because I went all out. (Fuel pressure safety switch, digital rpm activation switch, bottle heater, electronic bottle opener, autometer c2 gauges, etc)
I am intending to build a seriously tough FI setup. Absolutely not N/A.
I appreciate all the feedback man, I dont know much about anything this serious. I am going to eventually have to go to a performance shop to get some blueprints of what I am all going to do and just want to get a basic knowledge of this so I am not going in there blind for the most part.
Thanks man, I unfortunately can not make a move like that until the end of this year.
My6speedZ
06-08-2012, 11:35 AM
Read some of the stickies in the FI section. Just search any questions you come up with and read read read, then when ever your read to pull the trigger call and talk to a few sponsors they will get you squared away.
87silverbullet
06-08-2012, 11:51 AM
^^^Good info here. Just lurk around in the FI section and read. You will pick up alot just reading what people post.
Everything has its limitations. On stock motors with boost, its the rotating assembly. The rod bolts can take a good bit of abuse but they can let go too. The pistons are pretty stout but can also let go if the tune is not spot on and more on the conservative side.
Once you upgrade the internals and there are different levels of upgrade as far as crank, rods, and pistons go. There is the high end stuff like AES offers Callies dragonslayer cranks and their ultra rods and CP pistons. Then there is the stuff a little better than stock like a set of Scat rods and Mahle pistons on a stock crank.
Then once you start to make some real power you have to worry about the heads lifting because of the deck being thinner, but that's in 1000+ rwhp category. When you head that route you need to start looking into six-bolt blocks and heads. Just to give an example though 98z28cobrakiller on here has a 370 iron block with AFR 225 heads with an 88mm turbo and at a weight of 3800 lbs on 24 psi has ran as fast as 8.98@154 and thats with a 4 bolt per cylinder set-up. So don't count out any four bolt set-up.
COPO9560
06-08-2012, 12:15 PM
With a 74K mile engine, you might want to start on the outside first and then work your way in. Buy the D1 kit, change to 317 heads to lower CR and buy Brute Speed's blower cam. Will get you a huge increase in power over what you have now and for the most part be a bolt on exercise. When you eventually break #7 piston ring land, you can upgrade pistons and rods, port the heads, change pulley and be in the 700+ range.
What I don't see in your current set-up and hopefully in your budget is a few supporting parts needed for this level of power. Rear end, drive shaft, torque arm, clutch and possibly brakes and roll cage should be accounted for somewhere. Spare T56 might be a good idea too if you hammer it at the track with slicks.
My6speedZ
06-08-2012, 02:17 PM
^^^ Good points as well. M6 with boost will turn that 10-bolt into chum.
I was in the same boat as you, searching high and low for more power. POOOOWER (Clarkson voice)
Now, I can't even enjoy my car much because my rear end is howling and I have to limp everywhere.
Raoul-Duke
06-08-2012, 02:37 PM
Thanks again guys, Sounds like I have some research to do.
Yep def aware of all stated above. Its gonna cost quite a bit, but honestly I am probably gonna do the power first cause Im sick of just being a bolt on f-bod.
I would get more satisfaction of the money spent when I start it up vs. (built t56, moser 9 inch/suspension) even if it doesnt move much sitting in my garage lol
81cuttysupreme
06-12-2012, 08:41 AM
My .02. If u don't mind the down time.....use your current block. Rebuild with forged. Get new heads if u want, keep in mind if you use old heads and have to shave them it could cost roughly half the cost of a new head. Then apply the boost and run with it. I am currently setting up a forged 347 with a fmic d1sc for about 8 to 9 pounds. My goal is 500rwhp. I will post once I have been to the dyno. Fyi, I paid for a used set of 243s and then had to pay another $500 to have them milled flat. I would have rathered get a cncd head.
81cuttysupreme
06-12-2012, 08:45 AM
Oh and don't be scared to just call one of the vendors here. I have talked to bob @ brutespeed quite a few times. Rpm is who actually built my engine for me, I know both of those guys can be very helpful.
87silverbullet
06-12-2012, 08:52 AM
You got screwed if somebody charged you 500 to just mill your heads flat. You sure they didn't angle mill them?
Cartek, one of the top shops out there only charges 120 bucks to mill heads.
Read the thread, I already stated about using his old block and the OP has put that into consideration.
TXSZ66AVLANCHE
I consider a 74k ls1 to still be a baby, a couple months ago I watched a 233k ls1 go on the dyno and make 313rwhp, stock engine never been worked on.
Tainted
06-12-2012, 08:55 AM
Boy did you get ripped off big time. Milling should only be $50-100 per head
