Fueling & Injection - Looking for p/n 8-pin connector on fuelpump harness
Darylofpv602
06-13-2012, 04:53 AM
Like the title says, im looking for a part number on the 8pin connector underneath the car, that hooks up to the fuel pump. it has 2 4pin connectors perpendicular with it.
Mine burned over the grey and black wires in the center. Think that could have burnt anything else? (i got a racetronix wire kit new im installing)
1998 camaro. need a pic?
TXSZ66AVLANCHE
06-13-2012, 05:28 AM
Send me a picture
Darylofpv602
06-14-2012, 04:25 AM
SORRY about the wait! I get off work late and its 110 outside here.
Here is the pic of the 8 pin
http://i1068.photobucket.com/albums/u454/Daryl_Autz/_DSC0030.jpg
Ollie8974
06-14-2012, 07:05 AM
Here are several possibilities,
http://www.eficonnection.com/eficonnection/default.aspx
http://www.casperselectronics.com/store2/
http://www.injectorrx.com/fuel-injector-connectors.html
http://www.pcsconnectors.com/delphi_terminals.aspx
https://www.pegasusautoracing.com/group.asp?GroupID=WEATHERPACK
Darylofpv602
06-14-2012, 05:43 PM
http://www.pcsconnectors.com/12047938.aspx
FINALLY!
Thanks for the links - VERY HELPFULL - I'll just bookmark this thread so i can have those links :D
Racetronix
06-14-2012, 11:36 PM
FINALLY!
That is a Delphi 150 series connector.
You require a Delphi 280 series connector special app.
Please e-mail our sales dept. with this info. You will have to replace the terminals on both ends to prevent this from happening again. If you are running an upgraded pump without our hotwire harness then this can be a problem as well.
Darylofpv602
06-15-2012, 05:02 PM
Roger - Thats what i was thinking - Glad you posted.
I did buy the hotwire kit, and noticed that issue as i was getting setup to install.
Ill throw an email out.
