Adjust throttle cable on TB so BLADE opens 100%
With the car NOT running, I had a buddy put the gas pedal
to the floor while I was under the hood and noticed
that the throttle body butterfly does not open to the bumpstop.
It only opens to about 80%, theres about a 1/4 inch gap
before it would hit the bumpstop.
I have a Shaner S2, so I'm wondering if I need to adjust
the throttle cable now so that it opens fully.
How do I adjust the throttle cable so it opens to 100%?
thanks
thanks
You may not beleive this but the solution to this has been covered before. Do ya see the little white button toward the top of the screen that says SEARCH??? If you click that button and enter the search term BUMP STOP MOD there should be 50 other posts like yours with detailed instructions how to do this.
Ahh, since you're new to this I've done it for you.
https://ls1tech.com/forums/search.php?searchid=239103
You're welcome.
Tony
(I know how to use the search key. Gimme a cookie)
You're welcome.
Tony
My gas pedal is completely on the floor(a friend is pressing it
with his foot) I am under the hood and notice that on
the OUTSIDE of the throttle body, the "tab" is not
up against the throttle body bumpstop, it's like the
throttle cable should be pulled another 1/4 inch.
If I pull on the throttle cable with my hand another 1/4 inch
then the throttle is up against the bumpstop.
I need to somehow "shorten" the cable so that
when it's "floored", it actually opens the throttle
body all the way so that it is up against the bumpstop.
I think my previous statement didn't make that clear.
I already searched on BUMP STOP and didn't find anything.
I have a Shaner S2 that already has the BUMP STOP ground
down a little to actually allow 100% opening of the butterfly,
now I want to take advantage of it, but my cable needs
to be "adjusted" so it's shorter, so that when I "floor"
it, it actually rotates the butterfly completely so that
the "tab" is up against the bumpstop.
thanks
thanks
I think JRP touched on this a little while ago. You have to shorten the cable up somehow. I really don't know how, I didn't have this problem with my 98. But someone posted how to do this about 2 weeks ago. I remember b/c I was reading about it right before I did the Bump Stop mod myself.
I'll try to look for you, Try searching for Throttle cable if I fail to turn up anything. Like I said, the post was made about 2 to 3 weeks ago in either the New Enthusiast, or the external engine forum.
Tony
EDIT: BadWedge, try this
https://ls1tech.com/forums/showthrea...throttle+cable
Tony
Last edited by PSU_Engineer; 03-31-2004 at 05:56 PM. Reason: Added link to some info
