TCI Flexplate powdercoated ?
I just got my new TCI SFI flexplate (Thanks Speed Inc), but it is powdercoated. Looks nice, but my concern is that the powdercoating can break down - between the crank end and the flexplate, causing the bolts to be loose. IE under the pressure from the bolts, heat from crank, and add (possibly) a little oil to the mix.
Anybody have any exp with this ?
Thanks, J
jman812@hotmail.com
Thanks, J
jman812@hotmail.com
Originally Posted by PREDATOR-Z
Don't worry! it doesn't get that hot down there. If it did you would be buying another tranny and not a flex.
Thanks for the reply. I did not think it would get that hot, just the combo of heat/pressure/oil. I really do not want to have any problems with the plate coming loose.
Gino,
It looks heavier, but definitly stronger. I believe SFI is basically a safety spec.
'J
