Oil leaking into maf????
I have a issue with my ta its a 02 ls1 randomly started leaking oil from the intake into the elbow where the intake and maf connect. What could be causing this? I changed out the pvc already and no fix.. The car was turned on every once in a while for the last 2 years doesnt get used much if this helps any...
Moderator
The "makeup air" side of the PCV is unchecked and flows
in reverse at WOT where you have crankcase positive
pressure and inlet trace negative pressure. A catch in
that line could help you out.
Thanks a lot! Do I really need to do all that? or is there a cheaper way around this never did it before but now that the car sat for 2 years 4 months later of driving it it started to.
