Gears & Axles - Rubbing noise from the rearend
View Full Version : Rubbing noise from the rearend
Meen95z
06-24-2012, 04:53 PM
Had a set of Motive 3.90 gears in my brothers 01' SS and when you turn right it makes a loud rubbing noise? Didnt do it before gears, seems to be getting worse. Put new bearings in it, replaced 1 axle and inspected them. Cant figure it out. Any ideas? Only when you turn right.
Meen95z
06-27-2012, 12:54 PM
Anyone have any suggestions?
hershey1
07-20-2012, 10:07 AM
I bet its a carrier bearing and shim.
fstr n u
07-22-2012, 12:29 AM
Is this an easy fix? I have the Moser 12 bolt with 3.90 gears and i have the exact same problem...only when turning right.
hershey1
07-23-2012, 11:53 PM
I actually had a few issues with the rearend. First I replaced the gears, then come to find out I had a bad axle causing noise only when I turned right. The axle was pitted right where the axle bearing rides. I would check that first. We got that taken care of, then a few hundred miles later a similar noise came back only when making a hard right and it was the carrier bearing. It was a fairly straight forward fix on the 10 bolt. Although the carrier bearing has to be pressed off, then the new one pressed on.
