Why 18 rear and 17 front?
Old 06-25-2012, 01:54 AM
ls1sickandtwisted's Avatar
Default Why 18 rear and 17 front?
Okay I knw people buy the 18s in the rear and 17s front I knw they do it for the stance and have the back look meaner but any reason for pefomance versus going 18s on all 4 corners?
Old 06-25-2012, 05:53 AM
redlineracing's Avatar
17's are also obviously lighter than an 18" wheels, so that is less weight up front. This obviously being beneficial for street/strip applications. I think it is mostly an appearance thing though. However, I could be wrong. It wouldn't be the first time.
Old 06-25-2012, 07:00 AM
Drokkers's Avatar
i do it only for stance. also it worked for the corvettes so it cant be that bad.
Old 06-25-2012, 07:34 AM
Captain Double Post
BOBS99SS's Avatar
I think a 18,17 set up would look pretty good for the street, i always liked a bigger tire in the rear, i mean the 17,15 thing caught on pretty well
Old 06-25-2012, 08:29 AM
The Batman's Avatar
Performance wise, you are better off with 17's all around for most "handling" applications.
Old 06-25-2012, 11:34 AM
Xsta Z 28's Avatar
I would never put staggered diameters on Camaro . . . no point to it . . aesthetically speaking . . .
Old 06-25-2012, 12:43 PM
Z28RS's Avatar
When I'm fortunate enough to get new wheels for my Camaro, I plan to put 17" X 9.5" wheels on the front and 18" X 11" wheels on the rear for both aesthetics and practicality. Aesthetically, I like the way a larger wheel and tire look on most cars. And, practically, I like the idea of lower rotating mass on the front of the car and a larger contact patch at the rear. But that's just my opinion, and, as my dad would say, "To each his own."
Old 06-25-2012, 05:13 PM
Donohue96M6Z28's Avatar
x2^^^
Old 06-25-2012, 05:26 PM
Its for a trans am its lowered 1.2 inches I currently have 17s on all 4 corners but the 17s are too tuckedin I'm not doing spacers so I woud have to go 18s to get wider on the back cus I can find 17x11 on the ZR1s so its I get 18s or buy 17s and pay 200 each to get them wide so I'm looking for the best set
Old 06-25-2012, 05:33 PM
transamtom's Avatar
I bought a set of 17/18 Vette Y2K's and put them on my V6 DD.
The reason I did it was I got the rims for cheap and I needed tires anyway for the chrome 16's so I thought why not upgrade to a larger size for a couple hundred more.
I think they look ok and the car handles well with 32/21 swaybars
Old 06-26-2012, 08:11 AM
totalchaos's Avatar
my car had them on it , when i bought it.
Old 06-26-2012, 10:42 AM
LS1121's Avatar
So I guess you guy's don't rotate you tires??? For a show car or speed racer it is fine but on my DD? Can't afford a New set every year. Yes my tires are directional.
Old 06-26-2012, 11:00 AM
Drokkers's Avatar
i only keep my 17/18's on for the spring/summer time, rotating is out of the question for sure. I have another set (18x9.5 255's on all four corners) for the fall/winter time. Those i do rotate. All in all, yes they work, some like it, others dont. Do what you want boss, its you car after all!!!
Old 06-26-2012, 12:58 PM
Paul Huryk's Avatar
Considering that the majority of braking is done by the front wheels and the size of big brake kits reflect that, a set of wheels with the same size tires 275-40-17 or 275-35-18 in all corners as an example makes sense. With a solid axle on anything but super smooth roads, I would be hesitant to go any bigger than 18" all around with a 26" tire diameter. 17" would probably work better in 75% of all race situations assuming brakes clear.
Old 06-26-2012, 04:31 PM
I would rather get 18s on all four corners but it putting 17s on the front are more beneficial as far perfomance or life longetivity then I'm all in for the staggered set
Old 06-26-2012, 05:27 PM
Ellsworth's Avatar
I have staggered 17's 18's
Has no real use, nobody even notices their 18's on the back, I can tell the fronts are 1" smaller though. but I wouldn't expect anyone but an enthusiast to tell
Old 06-26-2012, 07:43 PM
So u really have not seen any benefit in that set?
Old 06-27-2012, 05:58 AM
Ponch95's Avatar
Originally Posted by ls1sickandtwisted
Yea I knw bud ur rite but its just when people are disrespectful it just push my buttons but I'm already past this
It wasn't disrespectful it was simply a jab / joke / funny / so get over it.
and FYI I have 18x10.5's on the back and 17x9.5 on the front, why because I love the Z06 rims and it looks BA.
Old 06-27-2012, 08:15 AM
Spd-Kilz's Avatar
It's done on F-bodies because GM did it on the Corvettes. I don't mind the look of an F-body with staggered or non-staggered wheels, but a little part of me dies everytime I see a Corvette without the stagger.
Old 06-27-2012, 08:22 AM
Drokkers's Avatar
i couldnt agree with this statement more!!! well put!!
Quick Reply: Why 18 rear and 17 front?
