How to dyno an auto 4wd truck?
Old 06-25-2012, 04:56 PM
RezinTexas's Avatar
Default How to dyno an auto 4wd truck?
Truck is in sig.
There is a warning sticker under the hood that says not to put the vehicle on a 2wd dyno because of the auto 4x4.
Can I get around this by simply unplugging the solenoid on the front diff carrier housing? There must be a way around this.
Thanks
Old 06-25-2012, 05:24 PM
JaYZeig's Avatar
id say your best bet is gonna be to remove the front driveshaft
Old 06-26-2012, 12:56 PM
cyipher's Avatar
you cant select 2wd only?
Old 06-26-2012, 04:36 PM
RezinTexas's Avatar
yeah, I would like to avoid that if possible
yes, there is a button for "2Hi", but there must still be a reason the under-hood warning sticker is there
Old 06-26-2012, 05:03 PM
Mattyfresh89's Avatar
sounds dangerous to put it in a 2wd dyno, especially with a warning sticker from the factory...must be good reason for that
Not any local 4wd dynos?
I know there are some in texas for sure. Theres a pretty big following down there for 3000gt vr4s and dodge stealth tt's. I used to hear of people dyno-ing them on the old forum I used to be on, because I owned a dodge stealth.
I swear some of the people tha ran em were in or around houston too
PM me if you want, I can shoot you the link to a local 4wd dyno shop, I dont wanna get in trouble for posting it here
Old 06-27-2012, 04:47 PM
RezinTexas's Avatar
I confirmed with my tuner (Pat G) that leaving the selection on "2Hi" is ok for testing on a 2WD dyno. He has done this in the past without problems.
Hopefully this thread will help others in the future who seach for this issue.
Thanks for the replies!
Old 07-11-2012, 07:13 PM
philntx's Avatar
No problems at all doing this!
Quick Reply: How to dyno an auto 4wd truck?
