protwin
06-26-2012, 09:08 AM
Selling my rebuild project this jeep has been gone through from bottom to top with only the best parts built by professional. Only thing not done to it is a final paint job. Body is in great shape no cover ups or hiding rust here! Jeep drives great everything works perfect. See list of new parts
Engine built 800 miles ago 304 v8 heads rebuilt with new valve seals ans seats. Has a pulling cam as well.
New eledbrock 500 CFm carb
New electronic 50,000 volt single wire self contained distributor with 8 mm race wire set gaped 52 thousands
New water pump and all hoses
New temp sending unit
New poly motor mounts
New starter and solenoid
Radiator cleaned and ends removed and reaseled
New battery and cables
New clutch pressure plate and throw out bearing.along with linkage
New fully build transmission with all new parts with 2 inch drop on mounts for lift
Transfer case open up cleaned and gone through and resealed
New brute universal joints
New rear axels seals and bearings
New hooker headers with magna flow exhaust turned down past rear end
Warren hubs
New rough country 4 inch lift with new shocks steering stabilizer steering share bearing and seal
New alignment done 500 miles ago
New gas tank with new sending unit hose and fuel pump
Rollover valve and charcoal canister and line replaced new
Totally new brakes with steel lines 6 inches longer for lift with new master cylinder pads rotors and drums shoes all new
New emergency brake hardware and lines
New direct read autometer oil amp and speedo cluster with temp and fuel all new
2 new bikini tops
New windshield and wipers and arms and switch
New dash with lock glove box
All new poly body mounts
Custom welded doors for cj5
New mickey thompson 15x12 wheels with 33 x 1250 tires have 60 %
I am firm on price and do not need help selling it!
I will consider trades on z28 camaro , ws6 trans am 1998 or newer
Maybe a four wheeler 4x4
Please call 706-two 73-6416
pictures can be seen on my craigslist post. 6900 cash price 7500 trade value
Warren hubs
2 new bikini tops
