Test fitting Weld RTS 15x10's
Old 06-26-2012, 10:37 PM
Dirty Vegas's Avatar
Default Test fitting Weld RTS 15x10's
Seems like they stick out a bit too far? Maybe it's just me.
Front
Rear
Also seems like they are close to the bumpstop
Old 06-26-2012, 11:58 PM
wws699's Avatar
Looks about right to me!
What offset?
Weld recomends 15x4 med pad 1.50 bs
15x10 med pad 7.50 bs.. looks like stock length rear?
I ordered 9" for my rears
If you want the fronts in more you can go low pad and different front brakes
Old 06-27-2012, 06:49 AM
Captain Double Post
BOBS99SS's Avatar
Yeah looks normal to me from the front veiw, is the wheel turned at all,maybe just a lil?
Old 06-27-2012, 06:53 PM
What offset?
That's the sizes I bought. Just seems slightly out there. Could just be me. I'll get the tires mounted and see how it sits.
Old 06-27-2012, 07:26 PM
L84ARACE's Avatar
Should be fine . Looks good.
Old 06-29-2012, 02:20 AM
1999FirehawkLS1's Avatar
Mine seemed out there also w out the tire on my Bogarts the body shape being inward on the bottom is deceiving
Old 06-29-2012, 03:34 PM
Camaro396's Avatar
They always look goofy when the suspension is unloaded. Mount a tire and jack it up from the rear end not the body and they will fit up in the wheel well where they're supposed to be.
Quick Reply: Test fitting Weld RTS 15x10's
