Radiator for Lt1
Radiator for Lt1
I am installing a 96 carberated Lt1 in my 67 chevy pickup....my first experience with this kind of cooling system and I am wondering if I can use my stock radiator or if I will need a new one?
If I can use the stock one (4 row) which way do I need to hook the hoses up?
I have an after market surge can that I was going to run the steam hose into...
Thanks....this forum has been super helpful but I haven't found the answer to this question yet
I used the LT1 radiator when I swapped my 72' C10, worked fine, you just have to redrill the upper and lower holes because the radiator is narrower than the stock truck radiator. If you are using an automatic trans I would highly recommend an auxiliary trans cooler as well. The LT1 radiator cooler isnt large enough for our heavy trucks, especially while towing. I saw 210-220* when towing after a good B&M cooler was added (700R4).
