Quick question on the LT1 oil pressure sender
Since mine is a later 1994 car, the sensor is a t the back of the drivers side head. When we put the motor in, we noticed that the retard who pulled it chopped off the pigtail.
I see replacement pigtails at local auto parts stores... but they are all 2 or 3 lead pigtails. Do I just chop off the 2 unneeded wires and hook up the pigtail to the harness? I just want to make sure I'm doing this right... The Camaro has 1 lead from the harness to the oil pressure sending unit.
Most pigtails will have a lead for every cavity so they can fit multiple applications that might need them. Just depin or nip off the ones you don't need.
