General LSX Automobile Discussion - whats does your oil pressure run at driving temature?
trans_am_2000
07-03-2012, 10:38 PM
My oil pressure usually sits at about 36-38 at an idle after i drive it for a bit, is this the normal place for it, it puses about 45-50 when driving
parks450
07-03-2012, 10:56 PM
That's good pressure, mine is around 60 driving and 50 at idle. Your good tho
trans_am_2000
07-03-2012, 11:20 PM
i guess mine is 60 when driving, was thinking it whent up buy 10 instead of 20 lol
mjs1012
07-04-2012, 07:20 AM
Mines usually around 45-50 at idle when the engine is warmed up and 60+ cruising. I also have a melling oil pump tho.
DWake
07-04-2012, 12:00 PM
40-50 driving, 25-30 idle
BriancWS6
07-04-2012, 12:30 PM
Most of the LSx vehicles I've seen that have stock pumps idle slightly above 40 at operating temps.
trans_am_2000
07-04-2012, 07:27 PM
today mine was ideling at about 35 afther a half hour cruise
Camaro_94
07-05-2012, 08:11 AM
My Z06 is 45 at idle my Formula is at 40
Decadence75
07-05-2012, 08:33 AM
I idle at a stop around 22-25 with 38-40 driving
brody slomaro
07-05-2012, 10:56 AM
my idle its almost at 0 then driving it goes up
parks450
07-05-2012, 06:30 PM
^ thats not good.....
RsSean
07-05-2012, 07:12 PM
40-45psi hot idle 55-60 under light load 65-70psi WOT Mobil 1 5w30 100*f florida weather.
brody slomaro
07-06-2012, 08:54 AM
I know I need a new oil pump lol
RPM WS6
07-06-2012, 09:09 AM
'98-'00 engines will have slightly lower oil pressure with the older style pump. A4 cars will also have slightly lower pressure at idle than M6s, as their stock idle speed is 250rpm lower in gear.
My '02 averages about ~5-10psi higher than my '98/'99/'00 cars did, all with the same oil and filter.
udienow
07-06-2012, 10:19 AM
Im a hair under 40 at hot idle (2002 M6)
beyonddisturbed
07-06-2012, 02:58 PM
I sit at 40 at idle and 60 driving
SippiSpeedhawk
07-15-2012, 02:40 AM
Sounds like you need new bearings too.
99Bluz28
07-15-2012, 02:53 AM
About 41 at idle, 60 driving.
DREAMZ28
07-16-2012, 02:43 AM
Probably about 28 at idle, maybe 38-39 cruising stop light to stop light, doesn't go above 40 unless it's hard acceleration.. Is that ok?
FST SS
07-16-2012, 11:23 AM
^^^this is mine and 80+ at WOT
trans_am_2000
07-16-2012, 11:49 AM
How many of you have aftermarket oil pump, and when do you need one
FST SS
07-16-2012, 12:23 PM
Mine is stock. Car has 70,000 miles
usmcpi
07-26-2012, 01:16 AM
Either your car is f*cked or your sending unit/gauge is wrong
But my ls1 is think is like 50-60 while driving. like mid 30s idle.
raptorblackBird
08-05-2012, 06:00 PM
98 TA w/ 195k...25-40, 99 TA w/125k...25-40, 98 C5 w/95k...35-60, 96 SLP w/108k...30-60
Posted from LS1Tech.com App for Android
ULTIMATEORANGESS
08-05-2012, 06:55 PM
thats what mine is. but im fairly upgraded.
Lee12609
08-05-2012, 07:14 PM
i was under the assumption the relief would open right at 60psi even on aftermarket pumps. extremely high pressure is not good.
