F1 procharged F-bodies, I have some questions..
I've been thinking about possibly procharging my f-body, I think I can get a good deal on an ls7. If I did this I'd want an F1-something head unit but I wanted to know who's running one?
What bracket are you using?
What pulleys?
What's your intake/filter setup?
What's your engine setup and how much power are you making?
Thanks.
What pulleys?
Thanks.
Mine should be up and running by next week.
I'm using a f1a 8 rib with aster bracket
Using snow meth kit and 93 pump gas
Running a aes built 390 using lq9 block
Should be around 800rwhp somewhere around 15/16 psi
I should be able to drive car anywhere I want to.
personally i would not go with the ls7 block. its a great NA setup. you can get 600+ at the wheels with it. but its said that its rather brittle and the cylinder walls are thinner which is why typically boosted setups are 370-408. not to say people have not done it. I just look at the big picture. Grab an ls2 block or lq9/lq4 off of classifieds. there is an lq9 block on there now already prepped and machined waiting for assembly. guy prob spent more on the machining that he is asking for the block.
What pulleys?
Thanks.
What pulleys?
Thanks.
7.65 lower 3.70 upper 16.5 lbs
Heintz Racing ported LS2 intake, Procharger truck inlet hat with Bobs Procharger filter
Heintz Racing aluminum block 370 LS2, 927rwhp/834rwtq
I drive this car everyday. Thanks jeff
F1A with steel J bracket and poor mans belt wrap. I have no belt slip
Did you have to modify the radiator support for the intake?
What intercooler are you running?
I dont have any pics but there are tons of pics on this forum I did mine exactly the way it said in the right up. I did have to cut a little of the radiator support for the inlet hat but not much and Im running the Procharger fmic for a fbody. jeff
Found it all, thanks again for the info.
