General Maintenance & Repairs - Vibration after burnout
98PurpleF-Bird
07-10-2012, 10:02 PM
So my car was in Park for like ten minutes after starting her, and as I was about to leave some co-workers asked me to do a burnout. I didnt want to go overboard, so i just let on the gas instead of doing a standstill. So after I do a little screech show my car got a weird vibration and I could feel it in the steering wheel when Stopped. the wierder thing is that the vibration goes completely away after I step on the gas, but as soon as my car stops it feels like if something gets un-engaged and starts vibrating. Then when I step on the gas it takes like a sec. for the trans to kick in and I feel a little kick.It did This at every stop. The trans. went through all gears flawlessly, it was just when I would come to a stop and take off???
98PurpleF-Bird
07-10-2012, 10:09 PM
Also I tried searching for like an hour and could not find one thread with relevant information.
98PurpleF-Bird
07-11-2012, 07:09 PM
well today when I started my car it wouldnt vibrate anymore, I burned out again and it wouldnt do it anymore. My guess would be the tranny is on its way out. Oh, and thanks alot I really appreciate it. I wouldnt of gotten anywhere if it werent for you all.
Sladester2
07-11-2012, 08:02 PM
Yw. I hope the tranny fails on you
98PurpleF-Bird
07-11-2012, 08:29 PM
fuck you asshole.
blade2222
07-12-2012, 06:20 AM
I've gotten that sort of thing after driving hard then later it starts acting normal. I wouldn't worry about it.
ramairetransam
07-12-2012, 09:08 AM
how does your fluid look? black burned or okay
98PurpleF-Bird
07-12-2012, 09:22 AM
It looks a little bad.. its not really black or sludgy but I can tell it hasent been changed..Thanks for the advice, and I didnt mean to blow up like that, just had a long day...I did kind of come off as a jackass..anyways now seeing my fluid I'm probably going to change my fluid and filter. anything else I should look at while im under there?
blade2222
07-12-2012, 12:23 PM
Transmission fluid.
blk97z28
07-13-2012, 07:51 PM
OP start with everything simple then go from there!
98PurpleF-Bird
07-13-2012, 08:03 PM
Thanks for all the help you guys! well Im going to try changing my fluid tomorrow and see what goes from there. so far its been alot of restoraton with this car. when I got it, it was a mess! It took me a good 3 months to get it back to stockish shape. I still dont know what has been done to the motor, as far as I know everythings stock. the only thing that was worrying me was that my lever has the cruise control button pushed in and it wont come out. it looks like someone removed the cruise control. Is that a mod or was it probably not working? Would it be better to put it back on?Thanks again for all the help!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
