LS4 Performance - Brake Fluid Change
kweevuss
07-11-2012, 05:14 PM
I was thinking about doing a flush on the brake system. I was wondering what DOT fluid I have to use. Is DOT 4 ok or what should it be?
91parkave
07-12-2012, 03:43 AM
Dot 4 is more than adequete
Panther427
07-12-2012, 06:22 AM
Dot 3 should have been standard. Dot 4 will be an upgrade higher boiling point.
Dot 5 should never be used in a car with ABS
Sadden
07-12-2012, 09:07 PM
Dot 5 should not be used on pretty much any car. As it is desgined for motorcycles and uses silicone as opposed to glycol.
Dot 5.1 is compatible with cars. As it is glycol.
kweevuss
07-12-2012, 09:08 PM
Ok it sounds good, thanks for the info
El Cid
07-13-2012, 09:29 AM
The owners manual states:
"DelcoŽ Supreme 11 Brake Fluid or equivalent DOT-3 brake fluid".
Hope this helps.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
