Can I use T56 on a PCM that came out of a A4?
Old 07-12-2012, 07:40 PM
2win_SS's Avatar
Default Can I use T56 on a PCM that came out of a A4?
I'm putting a LS in my Chevelle. I came across a good deal on a PCM from a A4. but I want to run a M6. is It possible to run a M6 on a A4 PCM? Or do I need a M6 PCM?
Old 07-12-2012, 09:44 PM
zamora7's Avatar
From what I heard you can, all is needed to run properly is to turn off the parameters or whatever they call it with a tune. You can not run an A4 with an M6 pcm tho. Best thing to do would be to call a tuner and make sure.
Old 07-12-2012, 09:52 PM
mjs1012's Avatar
You can have a tuner reflash it to an m6 PCM. I also heard that dealerships can also do it. But yes you can use it.
Old 07-13-2012, 01:32 AM
2win_SS's Avatar
Thanks fellas
Old 07-13-2012, 09:41 PM
gMAG's Avatar
No need to reflash your ECM. Mine was originally an A4....then went to manual.
When you run the manual trans, there will be no need for the ECM to control shifting. The ECM will still send a command to shift the A4, but the command will go nowhere, being that it's no longer hooked up.
