Fueling & Injection - Turbo Camaro e85?
View Full Version : Turbo Camaro e85?
coryratcliffe
07-18-2012, 05:26 PM
Hello... I have a Turbo ls1 camaro Dyno'd at 530rwhp and 540 ft tq at 8.25lbs 10.8afr and 11* timming. my question here is my injector duty cycle on pump gas is only 60% would i have enough left to be avble to run a e85 setup i have the fuel system for it just wanna make sure my 60lb injectors are up to the challenge.
deatschwerks
07-19-2012, 10:34 AM
Are you looking for more power with E85, or just tune it to where you are currently.
You should have enough headroom in your current system to switch to E85, but you'll be getting close to the safe limit if you end up pulling a little more power out of it.
coryratcliffe
07-21-2012, 03:33 PM
Well I know I have the pump and fuel system my injectors are the hold back what's the safest percent duty cycle before its to much
deatschwerks
07-23-2012, 10:11 AM
It depends on the injector.
Most injectors can handle 90-93% IDC. Beyond that, they essentially go static.
When putting a fuel system together, it's a good idea to give yourself some headroom, and that is why most suggest running in the low-mid 80% range.
black06g85
07-23-2012, 10:50 AM
85% usually is the max you want to run, but my friends car (I tuned) is running a si blower @8-9 psi on a 60's and with the BAP turned up 75% it's only hitting @86% or so.
