Machine shop not comfortable line honing mains
Took my aluminum LS1 block to my machine shop this week and im building a forged 347. Stock crank, Eagle H beam rods, Mahle forged pitsons ARP studs all the way around, clevite 77 bearings all the way around as well.
When questioning my machinist (Who has ownded his shop for 26+ years) About line honing the mains he didnt feel it was nessacary. After a brief discussion about how the ARP studs have more clamping load on the mains and it distorts them ever so slightly, he understood why to hone the mains. His only concern was with the steel main caps and the aluminum block if that was going to casue some havic when he starts to hone with the aluminum being the softer material.
What can I tell my machineist to make him more comfortable honing out the mains?
Nobody that I have talked to in my area that has experience with LS aluminum blocks. He has done almost a dozen SBC for me in the past but thats apples to oranges... He just doesnt like the idea of the sofer material in the block and the steel main caps. He has done aluminum blocks before he did my former shops 427 BBF in the shops 68 fastback so i know he has done aluminum. Any body who has machine shop experience have trouble with honing mains or what all do i need to tell him to do to the mains when he is honing the mains?
Hate to state the obvious, but put the studs in, tighten the caps down and have him check them. You may not need to line hone at all. If you do, some shops have a fixture to mount the block "right side up" so the weight of the hone is on the mains. Also, he'll have to use the right SC stones. I'm with the other guys though, unless you get some kind of guarantee, I wouldn't have someone who's hesitant or inexperienced do the work.
LS1Tech Premium Sponsor
We check each block that gets an ARP main stud kit to ensure if they need line honed that it gets done, but I will tell you they do not ALL need it!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
He is the only guy in my area that is WILLING to touch an LS motor...
Mullen NE 69152 we have more cows than people, google earth is sometime 69152
Your machinist has a legitimate concern. In working with the new Gen 5 blocks at work, the L83 which is the 5.3 truck motor, they have cast caps and the mains are honed. The LT1 motors have a nodular main cap and we now BORE the mains because we noticed a problem honing the soft block and hard maincap. I don't know the material of the LS1 caps, but in what I have seen at work, your machinist has a legitimate concern.
