need advice on rear springs
Old 07-23-2012, 12:19 PM
flewbyyou04r1's Avatar
Default need advice on rear springs
looking for a set of rear springs.. looking for stock ride hight.. all around good performance springs car is mainly street driven and would like to be able to hook on the drag strip. should make about 800rwhp with a d1sc..
Old 07-23-2012, 12:25 PM
LS1121's Avatar
Did you check the used parts forum here?
Old 07-23-2012, 12:55 PM
i need advice on what weight/length/brand
Old 07-23-2012, 01:22 PM
trans_am7935's Avatar
need more info.
is your car:
stock weight?
do you have a roll cage?
aftermarket suspension?
rear/front weight ratio split?
rear end and gear ratio?
transmission?
Old 07-23-2012, 01:24 PM
metalmilitia606's Avatar
Just use the stock springs with good shocks.
Old 07-23-2012, 02:13 PM
is your car:
stock weight? YES
do you have a roll cage?NO
aftermarket suspension?YES, STRANGE S/A F.R ADJUSTABLE EVERYTHING IN REAR
rear/front weight ratio split?I DONT KNOW FACTORY SETTINGS BUT HAVE 2 12IN SUBS IN A BOX ALSO
rear end and gear ratio? 3:73
transmission?4L60E
Old 07-23-2012, 07:14 PM
stock LS1 rear springs with the stock rubber mount should work fine in your application. the slightly bigger axle tubes should offset the extra weight of the subs in the back. should sit pretty close to stock. and stock rear springs work pretty good at the strip with the right suspension setup
Old 07-24-2012, 03:31 PM
Originally Posted by trans_am7935
stock ls1 rear springs with the stock rubber mount should work fine in your application. The slightly bigger axle tubes should offset the extra weight of the subs in the back. Should sit pretty close to stock. And stock rear springs work pretty good at the strip with the right suspension setup
ill try it out! Thanks!
Old 07-24-2012, 06:35 PM
LT1 springs are a little bit softer, but just by a little, if you wanted a little more squat
Old 07-24-2012, 06:55 PM
I'll try with what I got and go from there.. Thanks for your input!
Old 07-27-2012, 10:43 AM
OldCobraGuy's Avatar
What do you mean by squat? On launch? That is not a desirable feature...
Old 07-28-2012, 09:25 AM
DarkblueTA's Avatar
If you need a set of stock rear springs, I have a set. Pm me if you want them.
