Intake Manifold help!
IF anyone can send me to a link where it shows images and directions on ow to take of a intake of a 1994 camaro z28 and replace the gaskets. Hopefully their is one.
The intake manifold removal portion of this article should be what you need.
http://shbox.com/ci/cam_removal.html
This one has a small snippet about installation at the bottom. Just make sure you seal up the back of that intake manifold good with silicone
http://shbox.com/ci/cam_install.html
Try shbox.com. It has a diagram of the intake manifold and all it's bolt holes in an exploded view. You just need to remove your air intake off of the throttle body and disconnect your fuel lines. Then take the bolts out of each side
About the Fuel lines, is there a certain tool i should use to disconnect them?
Yes. You'll have to get some fuel line disconnect tools. They're kinda hard to get off so I just ended up taking my fuel rails off when I took my intake off. But you can pick up the tools at auto zone or oriellys. Here's a good pic of the set I used and how to use them
while shoebox.com is a wealth of 411....a haynes service book you can buy at most auto parts stores or amazom.com would have the info
REALLY clean the surfaces with acetone or something similar before installing and let the motor sit overnight before starting so RTV can cure
