Shop Clean Up - Precision,LS3,Holley,MS4,Comp,PST,Mickey Thompson, & More
Category: Accessories
Price: $1
Location (State): MO
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, Small Block, Big Block
LS Engine?: Fits LS Engine
KEEP Checking as we will be adding items daily.
All items are OBO and do not include shipping.
Call us at 417-724-1320 if you have any other questions.
SLP EXHAUST SYSTEM Part #31085,BRAND NEW IN BOX.F-BODY,POWERFLO, w/3.5 SLASH TIPS, Stainless steel -$545.00
PST 3.5" Aluminum Driveshaft TH400 to 9"- $325
LS1 Stock Injectors - SOLD
BMR Th350 Transmission Crossmember - $100
Comp Short Travel Hyd. Race Lifters Part # 15956-16 (Used) - SOLD
Comp Cams Pushrods Part# 7937 - 7.050 Long .080 wall - $75
Comp Cams Magnum Pushrods Part#7642 - 7.650 Long .080 wall - $75
Trickflow Pushrods 6.500 Long .080 Wall - $75
Comp SBC Cam - Roller (NEW)236/236 580/572 115lsa $225
2010+ Camaro Exhaust Manifolds (2 sets) $150 set
2005-2008 Corvette Exhaust Manifolds - $105 set
GTO Exhaust Manifolds - $100 set
6.0L Exhaust Manifolds - $100 set
High Performance Turbo 400 transmission w/reverse manual valve body & trans brake.
Upgraded clutches and many other upgraded parts.
Built to handle 950hp
Includes Lokar firewall mount braided dipstick.
SOLD
Hughes Performance Turbo 350 transmission part# 35-1
Forward Shift Pattern, Manual Valve Body
$600.00 (Over $1100 New)
Mickey Thompson ET Street Radials P315/415R16 -$250.00
Mickey Thompson ET Streets 28x13.50-15 (Slight Rub Line - No Leaks Or Any Critical Damage)-$200
Quickfuel 1050 Carburetor - 4150/4500 Dual Pattern Flange - $650.00
NEW!! NEVER HAD FUEL RAN THROUGH IT BUT HAS BEEN MOUNTED TO MANIFOLD FOR DISPLAY..
1050 CFM Drag Race Carburetor. Dedicated and designed for the hardcore drag racer,
this carburetor is easy to adjust and will provide unmatched performance.
Made from premium aluminum throughout with billet metering blocks and throttle body it's lightweight and durable.
Each carburetor is hand-assembled in the USA and individually engine tested - it's ready to race out of the box.
Features include:
~ 4-corner idle
~ Screw-In airbleeds that have been recessed and moved out of the air way for less restriction
~ Race style aluminum main body with upgraded annular race boosters
~ 5-Emulsion billet metering blocks with screw-in bleeds for every circuit - fully adjustable
~ Lightweight aluminum fuel bowls with internal baffles, raised roof, re-designed fuel entry orifice and built-in sight windows
~ Quickchange jet plugs - allow for jet changes without removal of the fuel bowl (required screw driver is included)
~ Billet throttle body with Teflon® coated and sealed shafts that have been slabbed for added air flow,
~ Stainless steel throttle plates, and secondary adjustable cam bracket. Each throttle body is machined for both 4150 or 4500 style manifolds.
SOLD
Holley HP 950 Carburetor Part # 80496-1 (USED) - SOLD
Wheels and Tires for 350.00 bolt pattern is 5x4 ¾..
255/50/16 5.5" B.S.Tires are Sumitomo HTR 50 Came off a 3rd gen Camaro,will fit most Chevy vehicles -
SOLD
Precision Vigilante Converter - 3800 rpm stall - TH400 to LS1 -
SOLD
Ported Edelbrock Super Victor Intake - For 4150 Carb - $SOLD
LS3/L99 Heads (5364 Casting)- Complete with Valves,Springs, Retainers, Locks, Seals, Seats -
SOLD
LS3 Intake - $175
LS2 Intake - SOLD
12 Bolt Gears 4.56 Ratio - $85
HVH 4150 2" Aluminum Carb Spacer SOLD
Texas Speed MS4 112lsa - SOLD
Futural Motorsports Solid Roller 268/279 713/731 112lsa - $265
Comp Nitrous Cam 239/247 623/623 109lsa $250
Comp Endurex Solid Roller Vertical Tie Bar Lifters (NEW Only Had Oil In Them) Part #8956-16 -$450
Comp OEM Replacement Lifters Part # 850-16 (New In Box) - $180
SOLD
