Pressure Tested Coolant System
Old 07-31-2012, 02:09 PM
C_Rules's Avatar
Default Pressure Tested Coolant System
I pressure tested my coolant system to check for any leaks and every time i pressurize it to 18lbs it slowly drops to 16 and then stays there. Any idea why it would do that. If there was a leak it wouldn't it keep losing pressure.
Old 07-31-2012, 02:18 PM
lt1slowz28's Avatar
small air bubble possibly.
Old 07-31-2012, 02:53 PM
C_Rules's Avatar
how would an air bubble cause that?
Old 07-31-2012, 04:04 PM
shbox's Avatar
You have a crack, leak, something that is able to hold at 16, but not 18.
Old 07-31-2012, 05:41 PM
lt1slowz28's Avatar
I don't know... Rob is probably right. most always is.
Old 07-31-2012, 06:01 PM
02v8ta's Avatar
I think most would be surprised how much their hose clamps can be re tightened if you take a screw driver to it
Quick Reply: Pressure Tested Coolant System
