Strange problem on 95 Z-28, please help!
Mods:
Lingenfelter Intake
Gutted Cat
Cat Back
Mad Z-28 tune
Problem:
A few weeks ago my girl told me that the car wasn't running smooth and it seemed like there was a miss present.
I finally took it to work (cold start-up), and it ran perfect. When I drove it home later in the day, it ran OK, but i noticed a slight miss when trying to maintain speed. Heavy acceleration, and normal driving seemed fine, but on the highway, it would miss under load at lower RPMS.
SO I swapped over my Coil (new MSD) and ICM (stock) from my 95 T/A and she ended up gettting stranded at work. I had to go out there and get the car running.
The car started right up in the morning that she got stranded, and would just crank and crank later in the day, but not fire up. For some reason it seemed as if the car wouldn't fire while cranking over, but would try to fire after i would let off the key.
After she got stranded, I changed out the plugs and wires (nightmare w/ stock manifolds), and the car wouldn't fire up, it kept trying to fire when I let off the key just like before. VATS IS DISABLED IN MY TUNE. I did get it to run, and it ran great in the driveway.
Heres what I have done so far:
New Fuel Pump (went out prior to this problem, and has been running fine with new pump for months) VERIFIED PRESSURE - PRESSURE IS CORRECT(38 at idle, 46 @ WOT)
New Spark Plugs (gapped to .45) and wires. NGK TR55 and NAPA wires that I ohmed out
Coil and ICM that I swapped over from my 95 T/A (was working perfect on my Trans Am before)
New DELCO Oxygen sensors
coated most electrical connectors with a small amount of dielectric grease
What's left:
OPTI
WATER TEMP SENSOR
IGNITION SWITCH
ICM (maybe the one from my T/A is no good from sitting for 2 years)
The car runs good without a miss until it is warm, but now that I have this start up issue. I am leaning towards the ignition switch ( I already have a new one ready to install), but I suppose it could be the other 2 things also? I had to replace the ignition switch on my T/A a few years ago, and the car wouldn't fire at all, not like this. But I also heard that the Ign Switch can cause drivability issues if it has a short.
Ideas?
I hear that the ignition switch is a very popular problem with these cars.
It still could be the ICM, but at this point I'm leaning towards the ignition switch.
What are some common ways to test the IGN Switch assy?
I have a new Opti replaced both front o2s, cleaned the MAF, new plugs, and just got an ICM and plug wires to install. While I do that I am going to space the coil away from the head per shbox.
I read this issue a lot on ths site and never really hear a cure.
Good luck I hope you can fix yours.
I have been in the electronics field for over 24 years and I hold a tube of ENVI-RO-TECH 16 Heat sink compound we use at work. It is silicone free. We use this on audio amps., PA finals or even some regulators that require it.
If you find you compound is dried out (it will be over time) you need new. Remember more isn't better in this case.
Back to why these cars have stumble at low RPMs when warmed up. If and when I find this problem I will come back and share and would appreciate any first hand knowlege of a cure in the meantime.
Thanks.
Like I said, the icm and opti are the most prone parts for fai
I do not know if changing out the ICM and coil contributed to his wife being stranded or know if the no start issue was present before this change.
