General Maintenance & Repairs - Power steering fluid looks milky whiteish
cdgreg
08-01-2012, 04:28 PM
Any idea what would cause power steering fluid to turn milky whiteish in color? Also, anyone know of any links to how-to change your power steering fluid?
BMR Sales2
08-01-2012, 04:40 PM
Do you have a power steering cooler on the car? If you do then mayybe the power steering cooler is allowing the coolant to mix with the power steering fluid.
mike171562
08-01-2012, 04:54 PM
another vote for the PS cooler , mine looked more like chocolate milk
cdgreg
08-01-2012, 06:28 PM
Damn good question. I have no idea, the guy I recently bought the car from seemed incredibly successful in life but at the same time unable to hold a coherent conversation, so I was unable to learn anything about the car. Where would I find the PS cooler and what would it look like? On that note, if I have a PS cooler is it OK that it is allowing coolant to mix with it, or is that a no-no?
sjsingle1
08-02-2012, 12:10 AM
its a big aluminum tube lookin thingy at the top by the radiator.....if you have 1......GET RID OF IT.....this has been a public service announcement
LT1559
08-02-2012, 01:51 AM
if you want to do the cheap route, like i did. just go buy some brass plugs and plug the power steering cooler. But DO NOT plug the power steering lines, instead loop them back together. I remember seeing someone on here say that they plugged the lines and I gave him a fair warning...2 weeks later the plugs busted and the power steering fluid went everywhere.
99'CajunFirehawk157
08-02-2012, 06:08 AM
Please use the search function, your NOT the first person with this issue, this has been discussed a LOT!
wssix99
08-02-2012, 07:24 AM
Foamy white is usually air. The pump could also be going bad.
99'CajunFirehawk157
08-02-2012, 08:00 AM
http://ls1tech.com/forums/general-maintenance-repairs/1019781-power-steering-fluid-milky.html
