Lifter Options Wanted
Well after getting my float issue figured out i think it did some damage to my used LS7 lifters i had in there. The lifter is taking awhile to bleed back up but once warm or driving the noise goes away. My question is should i replace them with a new set of LS7s or should i look into something more heavy duty? Im running LEs 223/230 .565 112lsa with a set of Crane double springs setup to run 155lb seat pressure.
