LS3 throttle body in a LS1 car
Old 08-03-2012, 06:38 PM
kyphur's Avatar
Default LS3 throttle body in a LS1 car
I'm swapping in a LS3 into my 01 Camaro and it has the stock LS3 throttlebody. I just found a LS1 to LS2 conversion harness and have a question.
http://www.texas-speed.com/p-1195-ha...1-vehicle.aspx
Is that all you need to use the LS2/3 for? What do you do with your cable? Just remove it?
Old 08-03-2012, 09:42 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
That is to convert a car than has an electronic LS1 throttle body, such as a Corvette.
You either need to convert to a different PCM, wiring & electronic throttle pedal to control the LS3 engine or retrofit to a larger cable style throttle body.
Old 08-06-2012, 01:32 PM
kyphur's Avatar
Thanks for the clarification.
Quick Reply: LS3 throttle body in a LS1 car
