17" Weld RT-S w/ CTS-V Brembo Caliper Mod?
Old 08-04-2012, 10:21 AM
Badger351's Avatar
Default 17" Weld RT-S w/ CTS-V Brembo Caliper Mod?
I'm looking to upgrade my front brakes on the TA using a set of calipers from a 2007 CTS-V. Although I want to throw some Weld RT-S wheels on in the future... but the questions is... will they fit? I was looking at the S71, with Medium pad height, 14 offset, and 3.80 back space, part # 71Mx7055N38A (http://weldracing.com/aitdownloadabl...itfile_id/306/)
Do I need to order a different pad height, more offset, or suck it up and go with the 18's?
Any help is appreciated!
Old 08-04-2012, 08:16 PM
Christian Dionne's Avatar
I don't believe they will fit. I have the 17x4.5 medium pads, and it doesn't look to have enough clearance. The sticky on the ctsv conversion says measure at least 1.25 inches from the caliper to the wheel to see if they will fit.
The weld website has a spreadsheet with all the gm cars, it says you need at least a high pad 17 to clear the newer SS.
Old 08-07-2012, 10:08 PM
1999Z28's Avatar
https://ls1tech.com/forums/suspensio...02-camaro.html
Use 17x5 5th gen Weld RTS wheels. They fit. You need the high pad wheel.
Old 08-08-2012, 02:31 AM
Badger351's Avatar
I saw that write up! I didn't know the 5th gen cars and ours had the same bolt pattern. (please correct me if I'm wrong) What part number are those 17x5 wheels.
Edit: Wait... nevermind! They are the same (virtually). AWESOME. I may go a little wider on the wheel... but loooks like I'm good here. Thanks everyone!
Old 08-08-2012, 04:05 PM
bill12690's Avatar
Our cars and 5th gens aren't exactly the same, but pretty damn close. Ours are 5x120.65mm or 5x4.75". 5th gen is 5x120mm or 5x4.72"
Quick Reply: 17" Weld RT-S w/ CTS-V Brembo Caliper Mod?
