Pick-up tube Bolt
Old 08-04-2012, 11:41 AM
badazz81z28's Avatar
Default Pick-up tube Bolt
Does anyone have a trick to ensure this bolt stays put? I tried to call STAGE 8 locking fasteners with no luck....They suck!!
I can loctite it, but with just a tiny bolt holding such a crucial part, I want some security.
Old 08-04-2012, 11:43 AM
mjs1012's Avatar
you should be good just torquing it down.
Old 08-04-2012, 01:19 PM
derrickman05's Avatar
X2. I just torqued mine tight by hand.
Old 08-04-2012, 02:26 PM
NVR_SPDS's Avatar
All it really does is hold the pickup tube in the pump. It doesn't have to support the weight of the tube PR anything like that. I just tightened the few I've done by hand, and didn't think twice about it.
Old 08-04-2012, 03:36 PM
mjs1012's Avatar
exactly what i did. the tube is actually bolted down on one of the mains on top of the windage tray. just dont tighten the hell out of the bolt on for the pump.
Old 08-05-2012, 06:40 PM
Well....I installed it....I always feel aw worried with these kind of things. That bolt is pretty small and does an important job. I put some red loctite on it, used my torque wrench on the lowest setting (5 ftlbs) to make sure it was at least that...
Old 08-05-2012, 08:49 PM
wildcamaro's Avatar
Just torque it to the spec listed...then engineering has already been done for you...
Old 08-05-2012, 11:23 PM
sjsingle1's Avatar
you can safety wire it if you want
Old 08-06-2012, 09:00 AM
mjs1012's Avatar
You'll be fine. What I did when I put my new pump in was filled it with oil and lubed the o ring so it slid right in. When you go to start the car up pull the fuel pump fuse so you can prime the motor and check for oil pressure.
Old 08-07-2012, 09:51 AM
Turtle Bite's Avatar
BRP makes this little two-bolt bracket if you are really that worried about it.
http://www.brphotrods.com/mm5/mercha...ory_Code=CNV14
Just think there are millions of pickups running around with one bolt in them, it will be fine.
Old 08-07-2012, 09:55 AM
Yea I know...I just know they were torqued to spec with multi-million dollar pieces of equipment and mine was torqued by me lol....I put loctite on it and tightened it. It will ok....I just worry...
Old 08-07-2012, 12:34 PM
Where were you a week ago! I would have wanted to have one of these!!! lol...
