how to figure out backspacing for a smaller rim?
Old 08-04-2012, 02:00 PM
SR-71 SS's Avatar
Default how to figure out backspacing for a smaller rim?
so I am working on a 69 opel gt to swap in a LS motor and bring it back to street legal
https://ls1tech.com/forums/conversio...9-opel-gt.html
As part of this process I am selling the slicks/skinnies currently a 15x12 or 13 rear and 15x4.5 fronts and would like to put a 15x10 rim out back and probably a 15x8 up front.
What measurements do I need to take off the old rims, or the vehicle to center the smaller rims in the wheel wells? I have read the stickies and didnt see how. any help would be most appreciated. Thank you.
Old 08-04-2012, 04:11 PM
VinR1's Avatar
Do you want the new wheels centered in the wheel wells or to sit the same way in relation to the fenders as the old wheels?
Old 08-04-2012, 06:36 PM
SR-71 SS's Avatar
Same relation where the outside edge lines up with the fender
Old 08-05-2012, 12:05 AM
VinR1's Avatar
Easy, see pic below to determine backspacing. For your rears, subtract however much narrower you want to go... fronts, add the extra width. For example, a 12" wide wheel with a 6" backspacing will set in relation to the outer edge of the fenders as a 10" wide wheel with a 4" backspacing
Old 08-05-2012, 08:07 AM
SR-71 SS's Avatar
got it. Thanks for the picture, makes it easy to visualize.
