im having many issues in my 01 t/a
Ok first off my power steering pump is leakimg finally found out where from. second power steering fluid got everywhere i think it may have damaged my a/c compressor b/c yesterday it was only blowing hot air and making horrible noises from under the hood. but when i shut it off for a minute and turned it back it blew nice and cold for a minute then back to hot air. And my alternator in the heat of the day at an idle drops from charging at 14 to just above the yellow area. Finally the weirdest part when my alternator drops to just above yellow my a/c blows cold. I have no idea what is going on pls help
Save the manuals!
I'd start with the AC and get that fixed. You just might have the AC and Alt going bad at the same time. If the AC is stressing the car more than normal, that can cause your voltage or the engine to bog.
