Sponsored by: CARiD
Cooling Problems
Old Aug 5, 2012 | 03:52 PM
azvette89's Avatar
Default Cooling Problems
I have a 99 corvette and like a lot on here have been having overheating problems . The temp is going past 220 while I'm driving mostly in the city. I have put a new thermostat, the rad fan relays, temp switch and coolant. My dash says low coolant but it's filled all the way up, will a bad coolant level sensor cause the fans to come on at different temps ? It seems like only the driver side radiator fan comes on when I turn the AC on, are both supposed to be on? I thought both are supposed to be on at all times. Any advice would be appreciated, thanks
Old Aug 6, 2012 | 10:26 AM
azvette89's Avatar
help anyone?
and also what are the relays for that are behind the headlights on both sides for? in between the coolat resevoir and headlights?
Old Aug 6, 2012 | 10:58 AM
LS1121's Avatar
don't have a Vette but most cars both fans will run with the A/C on because of the extra stress on the motor. Replace that bad sensor for coolant level, hell who knows what that is connected to. lol
Old Aug 6, 2012 | 01:58 PM
wssix99's Avatar
Save the manuals!
Originally Posted by azvette89
My dash says low coolant but it's filled all the way up, will a bad coolant level sensor cause the fans to come on at different temps?
Where are you checking the coolant level? In your overflow tank or in the radiator neck? It is possible to have low fluid in the radiator but not in the overflow bottle if the water pump is going bad and injecting air in to the system...
If the radiator has fluid in it, I'd look at the radiator next. Make sure there aren't any leaves, dead animals, or other things in there impeding airflow.
Old Aug 6, 2012 | 02:48 PM
azvette89's Avatar
I have a lot of fluid in the resevoir,when i get home ill go check the level in the radiator neck and ill also check if there is anything like leaves or trash in front of it.
thanks for the advice
Old Aug 6, 2012 | 05:32 PM
LS6427's Avatar
In the past 6 weeks I've been driving my friends 2002 Vette while my car is down for a new engine. It runs 220-230 in city driving. Its normal for Vettes to run hotter than F-Bodies.
Also, my girlfriend has a 2011 Grand Sport Vette I've also been driving a lot in the past 4-6 weeks.......it runs the same temps as my friends Vette in city driving on hot weather. On the highway it will drop to about 200-210 and stay there.
