5.3, LS1 or 6.0 ????
Old 08-10-2012, 08:50 AM
72 Z-28's Avatar
Default 5.3, LS1 or 6.0 ????
OK I'm having trouble trying to decide what to do. I just accuired a 98 Z, it has a rod hammering in the stock LS1. I'm trying to decide if I should rebuild it or get a 5.3 or 6.0 and swap all the LS1 stuff on to it. So what im asking is what would be the pros and cons in all cases? If I were to get a 6.0 I imagine it would be an lq4, and I dont want to buy pistons. So would the dished piston hurt power over the LS1 being fixed. Also what would I be looking at with a 5.3? And any other advice would also appericated such as things that may have to change....pushrods, headgaskets, if any etc...
Old 08-10-2012, 09:13 AM
FLASH1970's Avatar
What are your goals for the car? Forced induction, nitrous, heads & cam... hp level you want to be at? From what I've been reading, the advantages of getting either a 5.3 or LQ4 is that they handle boost better than an LS1. They are heavier seeing that they have an iron block, but they are also stronger.
Old 08-10-2012, 09:20 AM
72 Z-28's Avatar
Not going to be forced induction. I really just want to get it running cheap as possiable but I don't want to go down in power. Been looking around and I think it may be going up in power just by using a 6.0 block and rotatiing assembly.
Old 08-10-2012, 09:39 AM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
For getting the same or more power, I would go with the 6.0. Probably would end up being more budget friendly, but will also have more cube to play with.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old 08-10-2012, 09:44 AM
redtan's Avatar
Why not get an LQ9? More compression and should be just a cheap as the 4.
Old 08-10-2012, 10:49 AM
87caprice318's Avatar
but where are you guys finding these LQ9s at for good prices???
Old 08-10-2012, 11:52 AM
72 Z-28's Avatar
If I could find a lq9 as cheap I definatly would go that route.
Jake, do you know if there are downsides to the 5.3? If so what kind of a loss would I be looking at ie: 10 hp? I think a lq4 is going to be my best bet though.
I'm thinking that while I'm inside the engine I might do a small cam just because. I would like to not have to buy a stall though. I think a 224 doesn't necessilary need a stall? Also would I have to upgrade valve springs with this cam? Am I right on this?
Alot of my problem is im not sure if I'm going to keep this car after it is fixed.
Thanks for the input guys.
