valve seals cause power loss?
Old 08-11-2012, 04:34 PM
ghost-1's Avatar
Default valve seals cause power loss?
Ok so all my valve seals are pushed up to the valve retainer's. Would this cause low dyno numbers or just cause the excessive oil burn? I will upload a pic in a second.
Old 08-11-2012, 04:44 PM
EDS01SS's Avatar
well if they are pushed up that high and oil is getting into the combustion chamber because of that then yes you will lose horsepower because your fuel is being oiled down
Old 08-11-2012, 04:50 PM
ghost-1's Avatar
Yeah the pistons and heads where pretty coated in carbon. Its a 402 ls2 with a 224 cam fast 102 102 tb 9:3 compression kooks 1 7/8 headers ls6 heads with bigger valves and it only made 360 hp at the wheels. That number seems low even with the low comp pistons I am just wondering if that could have scrubbed that much power?
Old 08-11-2012, 05:10 PM
ghost-1's Avatar
they all look just like this
Old 08-11-2012, 05:36 PM
pairof69s's Avatar
yeah i'd say those seals are not doing a damn thing
Old 08-11-2012, 05:56 PM
ghost-1's Avatar
I am thinking when they did all the head work they never replaced them and that's what caused them to ride up like that.
Old 08-11-2012, 07:01 PM
outkast6991's Avatar
I'd be guessing the inner spring is pulling them up
Old 08-11-2012, 09:37 PM
sweet99ss's Avatar
Yep I bet they didn't change to the smaller valve for the smaller inner spring like they were suposed to.
Old 08-11-2012, 09:50 PM
ghost-1's Avatar
So there is a smaller seal that needs to be installed with dual valve springs? I have never heard of this.
Old 08-11-2012, 10:03 PM
sweet99ss's Avatar
Yea that's why the dual spring kits come with new valve seals....
Old 08-11-2012, 10:55 PM
ghost-1's Avatar
Yeah I am pretty sure they used regular ls6 seals.
Old 12-08-2013, 07:08 AM
GTOSPEED21's Avatar
Mine did the same thing. You have to use the blue valve seals. How much hp loss are we talking with all of them pushed up?
Quick Reply: valve seals cause power loss?
