Gears & Axles - 4.10's okay with a4?
buddhaz06
08-12-2012, 03:47 PM
i have an 01 z06 that has 4.10 gears and im putting an a4 in it for the 1/4 mile, and im just curious if the 4.10 will be okay? with the m6 it was crossing the line perfectly for the mph/rpm, so i figured the a4 will be the same since 3rd will be 1:1, therefore making it the same, unless i pick up major mph from the swap lol but i wasnt sure if it was too much down low in 1-2? probably gonna need a good dr or bias ply? like to get by with a 255-50 DR. any input would be great!
FirstYrLS1Z
08-12-2012, 06:21 PM
stick shift=no clutch slippage
A4=convertor inefficiency(slippage),it'll take a higher rpm to attain what you had before.
4.10s' with an A4 are 'borderline' for strip use,unless you're going to a bigger dia.tire.
hotrodth
08-12-2012, 06:24 PM
I know 3.73s are just right for an a4 w 27" tires.
buddhaz06
08-12-2012, 07:11 PM
It's basically strip use only. I don't have tires yet so I'll have to wait n see. My Redline is 7300
hotrodth
08-12-2012, 07:38 PM
what size tire?
buddhaz06
08-12-2012, 07:52 PM
I was using 26x11.5. I don't have any drag tires at the moment. I'll run it on street tires first and go from there. See if I need 26-28" tire.
z28241
08-12-2012, 08:06 PM
FWIW 4.10's+4000stall+27"tire on my setup
hotrodth
08-12-2012, 08:27 PM
I'd say 27" is the shortest tire id go with. 28" would be optimum w your setup
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
