Cylinder head 853's
Old 08-12-2012, 07:12 PM
mrada6998's Avatar
Default Cylinder head 853's
I recently bought a 2000 camaro. Its a head and cam car. I was told it had ls6 heads on the car. He had a receipt for the heads so I assumed he wasn't lying. Retarded *** move.
Took all the numbers down off the heads and heres as follows,
Casting number: 853
Drivers side stamped number: 9826916068229855
Passenger side stamped number: 8269r3362856
Can you guys help me out figure this **** out? any idea what I have on my car?
Thanks
Old 08-12-2012, 07:20 PM
hotrodth's Avatar
they are stock heads...sry to break the bad news
Old 08-12-2012, 08:07 PM
mrada6998's Avatar
damn it.
i appreciate the help, i just didnt see that coming because i have another set of stock heads that came with the car.
any suggestions on cheap heads that will help me make more power?
Old 08-12-2012, 08:25 PM
hotrodth's Avatar
what do you consider cheap? Texas speed had a great set of heads for 1300.00 prc state 2.5 5.3 heads. they are cnc ported and also raise compression. great heads...
Old 08-12-2012, 08:31 PM
mrada6998's Avatar
thats not too bad. is that what you run?
and i see you have gears in your car, with my big profile cam i wanted to do some gears so its not so bad in the low rpm, did the 3.73's make a difference?
Old 08-12-2012, 09:41 PM
OutrunNAScaR14's Avatar
3.73 in my car was one of the biggest differences I've felt. Cheap horsepower in gears.
Old 08-12-2012, 10:03 PM
mrada6998's Avatar
yeah i really wanna get like 4.10s or 3.90's....did you have an m6 or a4?
i didnt think that 3.73's would be a noticable upgrade for an m6 cause it already has 3.42's
Old 08-12-2012, 10:06 PM
badazz81z28's Avatar
They may be stock castings...but they could have still have work done to them. Butt dyno should be able to tell you that.
Old 08-12-2012, 11:24 PM
chevybayboy's Avatar
Get some 243 heads and get some head worj
Old 08-13-2012, 10:44 AM
mrada6998's Avatar
Ok. What's the difference between 243 heads and the Texas speed prc 2.5's?
Old 08-13-2012, 11:16 AM
baxsom's Avatar
243 heads are the stock heads that LS6 and LS2 cars came with (also badged 799)
some 243 heads had lighter weight valves.
the stage 2.5 heads from TSP are from a 5.3L engine. I have a set on my 00C5. For 1200 bucks, I got a compression bump, CNC heads, dual springs and when combined with my 228R cam dynoed at 240 to the wheels.
Old 08-13-2012, 02:59 PM
mrada6998's Avatar
240 rwhp? do you mean 440?
Old 08-13-2012, 03:41 PM
NC98Z's Avatar
243s are the stock LS6 heads. Texas Speed has 5.3 heads and LS6 heads with the 2.5 upgrades.
Old 08-13-2012, 04:15 PM
mrada6998's Avatar
yeah i was looking at their site, texas speed, and the flow number at a .600 lift are pretty much the same on both the prc and ls6 heads and the chambers are almost the same cc's. does anyone have a recommendation on one vs the other?
Old 08-13-2012, 04:32 PM
PRC LS6 heads have different runners than the 5.3 heads. They will make more power over the 5.3 heads all day long.
Old 08-14-2012, 10:23 AM
mrada6998's Avatar
alright. thanks alot for all the info.
with a non ported ls6 intake, shoudl i consider upgrading that when i do the heads or will that flow well enough?
Quick Reply: Cylinder head 853's
