GermanGTO
08-13-2012, 03:48 AM
So somehow my engine decided to spin a main bearing which caused my entire block and pistons to be fried. I've decided to go with a 402 build. I bought the block and had it honed out to a 402 and now I'm deciding on parts for it. So far I have these parts ready and waiting to be installed:
NEW GM 6.0 ALUMINUM BLOCK
NEW JE PISTONS W/ 10:1 COMPRESSION
NEW CALLIES DRAGONSLAYER CRANKSHAFT 24X RELUCTOR
NEW CALLIES H BEAM CONEECTING RODS
ROTATING ASSEMBLY COMPUTER BALANCED
CUSTOM GROUND HYDRAULIC ROLLER CAM .615 .625 LIFT
MELLING HIGH VOLUME OIL PUMP
COMP CAMS BILLET ROLLER CHAIN
HARMONIC BALANCER AND FLEXPLATE
NEW LS3 ALUMINUM HEADS WITH HOLLOW STEM VALVES,
NEW SPRINGS TO MATCH CAMSHAFT
NEW GM ROLLER ROCKER ARMS
ARP HEAD BOLTS
GM LS3 INTAKE MANIFOLD
NEW GM 38LB INJECTORS
So how am I doing on the build so far? Thoughts/suggestions. I think it's gonna be pretty good but maybe some of you more experienced gear heads could give better advice.
ARP HEAD BOLTS
