New Lifter Install
New Lifter Install
I decided to go ahead and upgrade to LS7 lifters while I have the heads off and the cam is still new. I ordered the LS2 trays as well. I plan to drill the bottom of the trays for better oil drainback (road race car), Question is, is there any pre oiling proceedure for the lifters before I stick them in the motor? Do I let them soak in a pan of oil for a while before hand or just install them Dry? I do plan on poly lubing the rollers prior.
LS1Tech Premium Sponsor
Soaking them in oil should be sufficient.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
