Race stars what tire should i wrap them with
Just purchased 15x10 and 15x3.75 Race Stars
Stock Height do not plan on lowering the car.
Built T56 and Moser 12 Bolt equipt
450 rwhp
Best 60ft 2,22 with nitto drag radials looking 1.60 or less
Car is driven on the street very little
What Size for the rear? 26 27 28
What size for the front?
I want the best traction possible
Would like to stick 275 size
ET Street Radial Pro
ET Street
ET Drag
Hoosier
450 rwhp
ET Street
ET Drag
Hoosier
Yeah I was pulling the trigger until the sales rep said m6 plus radial isnt good and top go bias MT ET street im assuming?
But that being said ill be going from 17rim to 15rim plus 26 tire to 28 tire so its got to be much better then what i got
What front runner Sportsman S/R 26X6.00R15LT or
Sportsman classic 26X7.50-15
i am currently using a 26x10.5 et street bias on my car. had to add rim screws and that will stop the rim from spinning inside the tire. and it was doing that with a 1.9xx 60ft. but get a bias ply for the front as well. if youre wanting to run a 28" tire then i would suggest it least 4:30 gears. if not and with like a 4:10 gear u can do the 26" or a 27" tall tire. i wil probably try going back to a hoosier qtp once my m/t are done for.
Yeah, the M6 will do better with the BIAS MT ET Street, i guess since you wont be street driving to much that'd be better. As for the sportsman, i think the S/R is worth the money as they wont have a tendency to leak down and they handle MUCH better than the classic.
Also if you do the BIAS ET Street, i would suggest the 28x10.50x15. Thats the exact tire i had in mind for that car. Or even an 11.50 wide if they offer it for a 15 inch wheel. I have CCW's so i run the 28x11.50x16
