Drag Racing Results - Update on my 2002 Corvette, 450 rwhp, PRC stage 2.5 heads, 1/4 mile times! SLOW!
Cody Strife
08-18-2012, 05:12 PM
Well i'm kinda disappointed with the results. I ran it yesterday at Alabama International Dragway and I was hoping I had a ticket in the 11's with ease. With 450 rwhp and street tires, I would have figured on getting high 11's, but 12.52 at 119 mph, doesn't that sound a little slow for a manual transmission c5 vette on streets?
2002 C5, M6, full bolt ons, PRC stage 2.5 heads and 228r cam, 450 rwhp.
My best times were as followed.
60' 2.096
1/8 8.29 at 94.16 mph.
1/4 12.52 at 119 mph.
My 2nd best run resulted in an 1/8 of a mile run against an over boosted WRX that had some interesting results...
My time is as posted.
60' time was 2.175
1/8 8.365 at 92.05 mph.
1/4 12.556 at 120.01 mph.
The WRX times was interesting, does 60' launch times really make this big of a difference on 1/8th and 1/4 times?
His time as posted below.
60' time was 1.809
1/8 8.226 at 87.65 mph.
1/4 12.791 at 107.36 mph. :confused:
I felt like I was playing catch up the whole damn time until the last 2/3 when I pulled by him with ease.
Somebody help me out here, I had probs with wheel hopping and getting the car to hook 1st and 2nd gear on that track, in fact my last run of the night I significantly lost traction from 2nd to 3rd and could have resulted in a wreck for the less experienced driver.
Is it the street tires that are holding me back? Is it the rubber engine and transmission mounts? Do I need to but additional bracing on my transaxle. Someone help me out...
Blwn_by_Twins
08-18-2012, 05:17 PM
Yes, 60's make a huge difference. You've got the speed for it, but those 60's are killing you. I cut a 12.1@113 with a 1.7 60' last month. This was on stock, full weight, M6, 98 T/A with 803 heads, a 221/221 .558 cam, and full exhaust.
Get some tires and lower those 60's.
A.R. Shale Targa
08-18-2012, 05:25 PM
Mickey Thompson 265/40/18s dropped my 60 ft from 2.3 to 1.85 on my 03 M6
ET went from 12.92 @ 114.4 to 12.29 @ 116.7.........as stated you have the
mile per hour to run low elevens...gl2ya
Sales1@Texas-speed
08-18-2012, 05:36 PM
Cody like others have stated this setup has 11s in it with ease, but you have got to get that sixty foot down. Put a sticky tire on it and shift those gears! :)
01_SuperSlow
08-18-2012, 06:33 PM
I agree with everybody here, that ET is too high for that MPH.
Those look more like Supra numbers! :D
sweet99ss
08-18-2012, 06:37 PM
Mph is pretty close depending on what the d/a was. Was it pretty hot out?
garygnu
08-18-2012, 06:58 PM
you have the power ,you just need to apply it.you need some suspension work and some sticky tires.
sweet99ss
08-18-2012, 07:02 PM
I agree he def has the power. I only trap 110 and I was damn close to being in the 11's. With those traps mid mid high 11's should not be a problem with good traction
Cody Strife
08-18-2012, 07:48 PM
Well I am open to recommendations, but I what I do know is that drag radials simply are not going on my car unless I brace that transaxle. To many examples I have read of differentials breaking away from that T56... (Not to mention it isn't the toughest rear end from what I have been reading)
I have bilstein sport shocks, any recommendations? Will poly mounts help with wheel hop?
garygnu
08-18-2012, 08:40 PM
look at better springs and poly mounts.consider some adjustable shocks .remove the front sway bar at the strip.slicks are easier on rear ends and absorb the torque shock better.
slinginrods
08-18-2012, 08:45 PM
120trap should easily be in the 11s.iwas 10.90s with128mph.your 60ft is killinyou,what are you leavin at?can you post the whole time card?
Way2Fast
08-18-2012, 09:45 PM
Ran 11.2@118. So, you definately have the MPH to run 11s, but like everyone else your 60' time is killing you. On the 11.2 run my 60' was 1.50. So, you can see what a .5 sec reduction in your 60' time is worth a hell of a lot. In comparison, that same car on street tires went 11.99 with a 1.88 60' time on street tires.
Footlead
08-18-2012, 09:54 PM
Even with those 60fts you should be running very low 12s. The car must be spinning pretty bad. My car went 12.30 @ 119.5 on street tires spinning with less HP and your car is probably at least 200lbs lighter. I cut 2.0 and 2.1 60fts spinning its ass off but hooked pretty good after I got it off the line with a automatic. The shifts are slow or your spinning.
Blk98Vert
08-19-2012, 12:29 AM
Get some better tires period
Ellsworth
08-19-2012, 12:44 AM
buy sticky tires, go out and learn to launch, drop time significantly off your E/T
hardcore4sure
08-19-2012, 01:48 AM
My one time at the track I ran 12.0-12.1@119 with a 2.1-2.2 60ft on Nitto DRs, almost the same combo as you PRC 2.5's 243's 11-1cr, EPS 226-226 cam , 420rwhp-400rwtq. It's hard to get outta the whole cleanly, but it makes a huge difference when you do. Get sticky tires and roll into it and your diff should be fine. Spinning street tires and wheel hop will break it much faster.
poloaa009
08-19-2012, 04:17 AM
http://www.couponsavings.info/rec/smile.jpg
http://www.couponsavings.info/for/smile.jpg
soundengineer
08-19-2012, 04:27 AM
Suspension is more the key....
Sticky tire will help, but its still gonna suck without proper suspension.
And your 60' is evidence of a lack of proper suspension setup...or possibly just lack of suspension all together
Cody Strife
08-19-2012, 05:32 AM
Thanks for the input everyone. Removing the front sway bar and installing drag specific suspension is not an option for me. I bought the Corvette no.1 for handling and speed.
But i'll probably look into some poly mounts, for the most part, I hear good things.
And yes to many poster, my car was spinning bad. In 1st and in 2nd and the VHT I don't think helps at all...
Drag radials, or a set of Nitto NT05 road course radials (200 UTQC) would be much better then my yoko s drive's that feel more like all season tires, lol.
Also, I have a fairly aggressive custom alignment, not anything to cause considerable wear, but there is definitely more camber in the rear. And again, i'm not willing to sacrifice any handling for the sake of drag racing.
If I get drag slicks they will go on spare set of wheels.
senicalj4579
08-19-2012, 07:11 AM
Get some mickey thompson or hoosier. For an all track tire get the hoosier but if you wanna put tires on and leave them for the street then get mickey. Remove the front sway bar. I did that and I was able to pop the left front tire when my car was stock internal/stall. 11.9s with 1.6s 60's
Mike Morris
08-19-2012, 09:50 AM
You might need a clutch too with that much power and drag radials. Combination of street radials and hot summer air caused you to run slow. Your MPH in cool air should be 120-122MPH.
TVWilkes
08-19-2012, 10:08 AM
Steele doesn't prep the track very much on Friday night. Get you some better tires and go on Sunday.
Sprayed1998
08-19-2012, 11:52 AM
Launch harder and shift faster. My cam only C5 Z06 used to run 11.60-11.70 @120-122 with 1.9/2.0 60's. Ur mph is there just need more seat time and a sticky tire.
Cody Strife
08-19-2012, 03:50 PM
Yeah, not to mention I bet a set of wider tires would help out. There is a reason c6 z06s run 11's with street tires.
they are 200 utqc or less, they are 335 compared to my feeble 285.
RonSSNova
08-19-2012, 11:46 PM
Why aren't you poking around over here?
http://forums.corvetteforum.com/performance-results-108/
Driving technique will help for sure. And, you can do better with different tires, not drag radials.
Drag radials will cause busted parts, hurt clutch etc.
For the Camaro guys, these C5's will hook very well with little to no mods. They just are fragile with a stick. A4 cars like mine need only tougher output shafts in the diff.
I made a few hits in mine with street rubber, never attempted a burnout, but went 12.0 @ 121. Drag radials, 11.30's so far, but it will go 11 flat when I can figure out how to get the friggin electronics to quit messing with me.
Cody, when you hook it better, you may lose a mph or two. Those dang stick cars really run on the back half......
FWIW, I have no idea what my RWHP is, don't really care, other than it's not enough! :D
Ron
3rdgentug
08-20-2012, 12:37 AM
looks on par with mine
hey just to be like everyone else , get stickys!
Dirty Vegas
08-22-2012, 01:30 AM
Did anyone say get sticky tires yet? lol. Try to shift it faster too, wring it out all the way to the limiter.
Marc 85Z28
08-22-2012, 08:56 AM
3 problems:
1. Budget street tires.
2. Poor driving.
3. Generous dyno. You're not making 450rwhp with that H/C setup.
LIL SS
08-22-2012, 11:50 AM
Last weekend I went 10.54 @ 122 with a 1.54 60', oh wait, I was out of gear :)
Really though, like everyone is telling you, get the tire to hook and I think you will be plesantly suprised.
