Changing heads.. PR's too??
Getting ready to swap to a set of 59cc Patriots. Currently running factory 241's with Comp 224/230. I'm assuming I'm going to have to change the push rod's to since the heads have been milled so much. So, is there anyway of taking an educated guess at how long they will be?? I'd like to go ahead and order them from TSP so I won't be waiting during the build and if they are wrong, no big deal, just send them back when I order what size I really need..
We can all take an educated guess but ultimately would put you back in the same situation if someone guesses wrong. I recommend purchasing the pushrod length checker or borrowing one from a friend that way you get it right the first time, and your not sending parts back and forth hoping it will work.
