Really needing help
Really needing help
Ok so ive spent the last bit of my day trying to figure this out! I have a 95 formula firebird lt1 auto trans. I'm curious on my stock gear ratio so I can get a set of 4.10s and apperantly I need to know what mine is stock. but my speedo is a 155mph. My trans shows no "1" its just P, R, N, D, 3, and 2. But it will drop down into a first. If that makes sense. But ive read that 155mph has one set and if there is no "1" it has different from the 155 spedo. My rpo code in glove box is missing so I cannot refer to that. also what is a good set to get? I was looking at either ordering a set through jegs or orileys. Has anyone ever had experience with the two?
jack up the car grip the drive shaft and roll it in forward motion to take out the slack in rear place a "mark"on botton of drive shaft and a "mark " on bottom of tire then roll the drive shaft and roll it forward a number of rounds ( count the rounds) untill the tire makes a complete round, if the shaft makes about 2 3/4 rounds = 2.73 = 2 series , 3 1/4 rounds = 3.23 = 3 series ( if takes about even 3 rounds could be 3.08 = 2 series)
good luck Johnny
good luck Johnny
