Pulling the axle on a 12bolt
I want to change my wheel studs on my moser 12bolt I have to pull the axles to do this how hard is it? Is it just the 4 bolts that hold it on?
Will I loose any fluids? Have to change any seals?
omg... you are just wanted to change studs out? WTF is everyone talking about... take your wheel off, pull the brakes, take the rotor off and then hammer the studs out, use spacers and lugs to pull new ones in. no pulling axle out... jeesh, the way I read that he JUST wants to CHANGE his WHEEL STUDS
Yeah no room for 3.5 studs by not pulling the axles plane and simple.
I have c clip eliminators so it was just the 4 bolts slid out easy and took about 20 mins per side
