Is the lower radiator hose, Camaro(2002) supposed to have a spring in it?
Most modern hoses do not have them. If you feel one is needed, they are easy to make. I bought a small spool of 16 gauge galvanized wire at Home Depot and wrapped it around a piece of pipe to form coils and then massaged it to where it would fit inside the hose. I had to drop a piece of cord through the hose and use it pull on the wire as I worked it into the hose. With the wire in there you cannot collapse the hose. Cost was less than $2.
