Flat top pistons with l92 heads
Old 08-30-2012, 06:42 AM
sixt5's Avatar
Default Flat top pistons with l92 heads
Do the pistons need to be fly cut? I know the cam has to be the deciding factor but I'm looking at around a 228/230+ or bigger duration and 600 or bigger lift.
Old 08-30-2012, 07:42 AM
redtan's Avatar
Only way to really know is to measure.
Old 08-30-2012, 08:08 AM
9sectruck's Avatar
I was told any thing over 230dur with a 112 or tighter lsa will be pushing it with the big intake valve
Old 08-30-2012, 09:12 AM
89ROC-Z's Avatar
Call up Geoff from EPS and he'll get you taken care of. You can fit a pretty big cam without flycutting....
Old 08-30-2012, 09:41 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
You still have a lot of room on the exhaust side on LS3/L92 heads, so LSA isn't as much of a factor as the intake centerline and intake duration is!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 04-26-2013, 04:34 PM
sixt5's Avatar
Bumping this back up. Geoff at eps got me hooked up with a 224 236 113 plus 2 cam. Problem is, I got the itch for a turbo so I ended uo calling up huron speed and getting a 78mm turbo. Hopefully it won't pop!
Old 04-26-2013, 05:30 PM
89gmcs15's Avatar
fyi i am running a lq4 (with ls2 pistons and rods) .011 out of the hole with unmilled ls3 heads and factory ls3 head gaskets (i believe its .051 crushed?)
my cam is,
INTAKE 234@50 / LIFT .628/center line 108
EXHAUST 250@50 / LIFT .621/center line 116
lobe seperation 112+4
and i fly cut .080 on both the intake and exhaust but i could have gotten away with less... maybe could have went .065 exhaust and .050 on the intake...
Quick Reply: Flat top pistons with l92 heads
