General LSX Automobile Discussion Non-technical LSX related topics.
head cooling pipe
Old 09-02-2012, 04:13 PM
Swt SS's Avatar
Default head cooling pipe
I am installing a 02 5.3L LS in my car...when I got the engine the head cooling pipe or stream pipe...was a single pipe in the back of the intake that went from pass. head to dr. side head....should it be like that? I have a 00 silveradro 5.3L that has the head cooling/stream pipe, but it is attached to both the front and rear of the heads...which should I use??.....tks
Old 09-02-2012, 05:26 PM
JaYZeig's Avatar
in my opinion, i would use the steam pipes that connect all 4 corners, lke on the ls1's.
they help with evacuating air pockets from the engine, and help with them rear cylinder temperatures because the coolant has a place to escape.
Old 09-03-2012, 11:26 AM
1970 LSCamaro's Avatar
I was wondering the same.....thanls for the info
Old 09-04-2012, 09:50 AM
Chawlz's Avatar
on my ls1 I had the unit that connected all 4 corners. it was cracked so I replaced it. new one from Chevy dealer only connected across front 2 corners and came with black off plates for rear 2 corners. not sure why they changed it.
Posted from LS1Tech.com App for Android
Quick Reply: head cooling pipe
