Squeak from front left
Old 09-06-2012, 10:22 PM
98ws6blk's Avatar
Default Squeak from front left
Here's a weird one.
I've got a squeak/clunk from the front/left when I'm backing up...mostly when the steering wheel is turned some.
Any ideas?
Old 09-07-2012, 08:23 AM
Save the manuals!
wssix99's Avatar
Check the bearings/hubs. If you have over 75K miles on them, the hubs would be suspect.
Old 09-07-2012, 12:04 PM
98ws6blk's Avatar
Those have to be replaced as a complete unit, right?
Old 09-07-2012, 04:46 PM
Save the manuals!
wssix99's Avatar
Yep. There is one connector for the wheel speed sensor and 4 bolts that hold the hub on.
To test the hub, you can jack up the wheel and grab it at 3 and 9 o'clock. If you pull side to side and get any wobble, that's a sure sign of a shot hub.
Quick Reply: Squeak from front left
