Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
2001 Camaro Z28 A4 *BROKEN*
Old 09-07-2012, 01:09 PM
BIGDATOWN's Avatar
Default 2001 Camaro Z28 A4 *BROKEN*
Year: 2001
Make: Chevrolet
Model: Camaro
Price: $3500
Mileage: 172000
Private or Dealer Listing: Private Listing
Location (State): AL
Color: Beige
Transmission: Automatic
Drivetrain: Rear Wheel Drive
2001 Camaro Z28 A4 with 172k miles. Car has nice black leather interior, cold a/c. Everything works on the car. The car has two issues. 1. It has a slightly burnt exhaust seat on cyl#6 resulting in slightly lower compression on that cylinder than the rest and causing a CEL. This cylinder still produces 180 PSI but all others are around 220 PSI. 2. I believe the car has a weak lifter in it as it does have a slight tick after some rpms. Other than that the car is solid. I Have put alot of time in this car to make it as close to perfect as possible AND I still daily this car everyday. No cheap parts were bought.
Aftermarket parts are:
PTC 3500 10" converter
Transgo HD-2 shift kit
Derale trans pan with built in cooler
16,000LB External trans cooler
Autometer trans temp gauge
Innovate wideband MTX series
Slp Lid/kn filter
BBk Longtube/ORY
Custom 3" exhaust through a 18" magnaflow
New parts are:
New fuel pump assembly
Motor/trans mount
Water pump
Belts/plugs
Oil pan gasket
Rear cover gasket/ rear main seal
Valve cover gaskets
Main vacuum T/ Bought from GM
Corvette o2 sensors
Car has ran a best of a 7.87 with me in it (330lbs) and a 7.75 with slota in it (175lbs) on a set of 235 et streets, and a best of 8.14 (twice) on khumo street tires. This car has alot of potential left in it. It has not even been tuned yet! Here is a video of its first time out with the new parts before the custom exhaust. Video is with the stock cat-back and a 3" cutout.
Car decided to spin a rod bearing on me while starting it. It has less than 10-15 secs of run time on the motor with the spun bearing. Asking $3500 obo or trade for a nice 4x4 cherokee
256-572-711ZERO Call or text
http://s815.photobucket.com/albums/zz79/donniecarr/
Old 09-07-2012, 05:44 PM
bass87gn's Avatar
Bump for a nice car, this car is just right down the street for me and could make someone a hell of a deal,car could be easily fixed
Old 09-08-2012, 10:25 AM
BIGDATOWN's Avatar
Thanks brad
Old 09-09-2012, 08:04 AM
BIGDATOWN's Avatar
Ttt..
Old 09-09-2012, 10:56 AM
Jvmun's Avatar
Where in AL are you?
Old 09-09-2012, 01:59 PM
BIGDATOWN's Avatar
Hayden, al
Old 09-10-2012, 08:21 PM
BIGDATOWN's Avatar
Sold!
Quick Reply: 2001 Camaro Z28 A4 *BROKEN*
